06-03-2018, 12:17 PM | #1 |
Newbie Join Date: May 2018 Location: ES
| Wheels for Wodoo PIN 2.2
I am looking for some light wheels for a Woodoo PIN 2.2 tires. They are for a Super Class project. I have seen the racing tires of RC4WD. Would these adapt me well? |
06-03-2018, 01:20 PM | #2 |
| Re: Wheels for Wodoo PIN 2.2
Are you building a super or a 2.2 rig? If building a super check out dluxfab.com or find 5th dimension on Facebook. They both make super class wheels. If you're looking for 2.2 like the rc4wd you linked to I'd highly recommend either dluxfab.com or again 5th dimension over those rc4wd wheels. They are much nicer quality than rc4wd by far. |
06-05-2018, 04:14 PM | #3 |
Thank you very much, maybe I'll buy wheels later, because now I've spent a lot of money and I'm going to take advantage of some that I have. Do you know if at the moment I can put the Woodoo in a wheel 2.2 standard beadlock? This is what I have? |
06-05-2018, 06:56 PM | #4 |
Sure, all ottsix tires will go into regular beadlocks.
06-19-2018, 11:19 AM | #5 |
Another question, regarding the components of the Woodoo Pin I have chosen: -Front wheel: Gold (Ultra Soft) -Rear wheel: Silver (Soft) For the foams I have more doubts. One option is Crawler Innovations And I have chosen the following: -Rear wheel: Double Deuce 6.0 "2.2 Foam (Standard / Medium) -Front wheel: Double Deuce 6.0 "2.2 Foam (Standard / Soft) Do you think the choice is correct? Thanks for all the questions |
06-20-2018, 01:29 AM | #6 |
Quarry Creeper Join Date: Apr 2011 Location: Estonia, Europe
CI's DD 6.0 foams are good choice but I'd take the Comp Cut version of them
06-26-2018, 08:34 PM | #7 |
Rock Stacker Join Date: Aug 2017 Location: Hinesville
Dluxfab.com should be the best go-to place for building a super.
Wheels for Wodoo PIN 2.2 - Similar Threads | ||||
pin drive wheels ? | lennartchurch | RC4WD Trail Finder 2 | 6 | 03-11-2015 12:59 PM |
pin mounted wheels | atf300 | Vaterra Ascender | 3 | 03-01-2015 06:34 PM |
Pin mount wheels on a CR01 | mtnhrdgr2 | Tamiya CR-01 | 2 | 03-29-2010 12:30 PM |
