10-15-2018, 12:03 AM | #61 |
Quarry Creeper Join Date: Nov 2016 Location: Switzerland
| Re: SSD - 2 New 1.9" Chrome Steel Wheel Options - Old School!
Colour finish is very bad and the edges are not as nice as they could be. they don't cling the tire. And I can't use the most narrow slw hub you offer Good thing about them, pretty heavy beadlock ring. They weight as much as the gmade sr line. |
10-15-2018, 09:06 AM | #62 |
Rock Crawler Join Date: May 2012 Location: Central PA
Very clean looking wheels. I'm using the SSD steel wheels but the bead lock versions and really like them overall.
12-11-2018, 10:20 AM | #63 |
Pebble Pounder Join Date: Jul 2012 Location: Northeast
Hey everybody, All of you that put these SSD slot wheels on your TRX-4 Bronco, what kind and size Super Swampers did you use? I just placed my order at RPP for these wheels and some Pro-Line Super Swampers. I just noticed a couple of pages back that High Plains Drifter used RedCat IROKs--are they a different diameter? Of course, I went with these wheels and Swampers to replicate what these rigs looked like when I was a kid. I guess I just assumed that the 4.75" tall Pro-Line Swampers would fit...now I'm not sure. I'd hate to trim the body to fit if they rub, or I guess I could move the body posts up. Can anyone confirm what I'll need to do to make what I ordered work? |
12-11-2018, 10:42 AM | #64 | |
Newbie Join Date: Jun 2018 Location: Tampa
| Re: SSD - 2 New 1.9" Chrome Steel Wheel Options - Old School! Quote:
The memory foam inserts that come with swampers are pure garbage, way too soft for that tire, no support. I went with Crawler innovations lil nova two-stage foams in medium. The swampers with the two-stage CI foams were WAY easier to get mounted. I also have a set of the BFG Krawlers in 4.75 from Pro-line and again used CI two-stage foams on SSD beadlocks. Same thing, fairly easy to mount with a little patience. Long story, short. They will mount, just need patience, maybe some trimming if using the foams that come with them or buy some pro-line or crawler innovations two-stage foams to make life easier and make them perform better. | |
12-11-2018, 10:56 AM | #65 |
RCC Addict Join Date: Nov 2017 Location: Austin Texas
I'm really happy with the Redcat IROKS and run them frequently in sandy/ muddy/ loamy conditions. Mounted up to the slots, they measure approx 116.40 mm x 44.35 mm. I really wanted the more aggressive IROK instead of the Super Swamper. I've got the Proline Swamps on another wheel and I like em okay, but the softer and more aggressive Redcat IROKS just rule on the trail... perfect amount of bite and flex to get up and over or through. When the suspension on my TRX4 Bronco is fully articulating and at full lock left or right, the Redcat IROKS occasionally rub just a tiny bit but it's not a big deal in the least. That said... I don't want to run anything any bigger than that. |
12-11-2018, 02:49 PM | #66 | |
I think I'm going to be on the lookout for some Redcat IROKs next. Last edited by RCTom; 12-11-2018 at 02:56 PM. Reason: fixed misspelled word | |
12-11-2018, 02:52 PM | #67 |
| Re: SSD - 2 New 1.9" Chrome Steel Wheel Options - Old School! I agree 100%. I have some of each type of these foams lying around so I'll probably do some experimenting after the new tires and wheels arrives.
02-09-2019, 10:35 AM | #68 |
Newbie Join Date: Apr 2018 Location: Canada
Question for you guys. I'm new to this R/C stuff and picked up a set of the Chrome SSD 5 slot beadlock wheels with the faux red locking hubs for my totally stock TRX4 Bronco. They look fantastic and my Bronco just screams 1979. LOL 1.9"Â* Steel Slot Beadlock Wheels (Chrome) Anyway what I noticed though is the when the wheels are installed the axle shaft (or in other words spindles) actually sticks out further than the length of the locking hub itself (which also acts as the wheel nut). Essentially my wheels need to come out about 2mm more for the locking hub to screw down and seat and tighten the wheel. SSD makes these aluminum hexes, but I'm not sure exactly what their intended purpose is, nor it doesn't say how wide they are. It looks like they might be the same width as the stock TRX4 hexes (5mm), but hard to tell from a picture. Does anybody have these SSD hexes, are they more than 5mm wide? This would be my preference if it will push the wheel out 2mm more. PARTS FOR TRX-412mm Aluminum Hex Set for TRX-4 SSD also has these hubs/rotors, maybe this is what I need in a 3mm offset, but I'm not really sure? This would be second choice, but only because I was planning to install the Samix brass kit that already includes brake rotors for appearance. 3mm Offset Wheel Hub with Brake Rotor Thoughts on what I need to do? Maybe I need both the offset rotor/hubs & the hexes? It's not really clear. |
02-13-2019, 06:09 AM | #69 | |
Newbie Join Date: Aug 2018 Location: Slovakia
Bronco has longer portal axle than defender(needed for center scale nut). Part 8255 vs 8255A, its about 3mm longer. You have few options. If you like current track width of wheels just cut the excess part with dremel or buy defender version 8255. If you would like 6mm wider track buy samix 8mm hubs, they add 3mm on each side. SSD +3mm hubs/rotors are option too, but not if you want samix potal covers with rotors. In my opinion ssd portal covers are better. I have it with samix 8mm hub. And this is with wheel installed. Last edited by Marek_k; 02-13-2019 at 06:12 AM. | |
02-16-2019, 09:10 AM | #70 |
Great info, thanks Marek!
10-31-2019, 05:12 AM | #71 |
RCC Addict Join Date: Oct 2014 Location: UK
| Re: SSD - 2 New 1.9" Chrome Steel Wheel Options - Old School! |
SSD - 2 New 1.9" Chrome Steel Wheel Options - Old School! - Similar Threads | ||||
SNEAK PEEK SSD 1.9 Chrome 8-Hole Steel Wheels!! | RPP Hobby | RPP Hobby | 1 | 07-03-2018 11:55 AM |
New SSD Wheel Hub with Spinning Steel Rotor | SSD | Tires and Wheels | 76 | 03-19-2018 11:17 AM |
Sneak Peak - SSD RC 1.9" Steel 8 Spoke Beadlock Wheels (White)! | RPP Hobby | RPP Hobby | 2 | 01-22-2018 08:10 PM |
SSD 1.9" STEEL D HOLE WHEELS question | desertdude | Tires and Wheels | 16 | 02-18-2016 03:30 PM |
