Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Help removing glued cut tires from wheel
Old 06-05-2020, 03:59 PM   #1
Default Help removing glued cut tires from wheel
Hey guys, I have these 2.2 tires that I was given that are cut down to 4.75ish area that are glued to some plastic wheels. Is there any way of ungluing them from the plastic wheels without messing up the glue joints on the tires? I don't care about the wheels since 2 of the hubs are stripped out. Not sure what tires they are but they're cool looking and might end up being my mud tires. If I can get them dismounted and find some cheap 2.2s for my Trx. Thanks in advance for any help and direction! It's much appreciated!!!
AnimalHippie is offline   Reply With Quote
Old 06-06-2020, 01:44 AM   #2
Default Re: Help removing glued cut tires from wheel
I would try cutting the center of wheel/spokes out , then trying using a Dremel sanding drum and going at the rim from inside out... All I got ..
Tires look like some I have seen on the amazon website....
Good luck.
jchammbone is offline   Reply With Quote
Old 06-06-2020, 07:48 AM   #3
ive had good luck leaving them in the sun then slowly pealing the tire back also vary carfull use of a exsacto knife and slowly scraping at the plastic while putting presure on the bead of the tire as long as you go slow and just scrape the rubber off the plastic you should be ok
ferp420 is offline   Reply With Quote
Old 06-06-2020, 11:53 AM   #4
Carefully wick acetone into the bead with a small glue brush or q-tip. Let it sit for a few minutes, then try working the tire off the wheel. It may take several applications of acetone, but it will work eventually.
Bob_in az is offline   Reply With Quote
Old 06-06-2020, 07:02 PM   #5
Thank you guys for the advice. I went ahead and tried out Bob's way and so far so good. Have only done one tire so far. Have broke a couple of the sidewall glue joints but that shouldn't be hard to fix. Any suggestions on adhesive for regluing? I've used E6000 for almost all my RC adhesive needs so far. Will that do the trick? I also found these are rc4wd rock crushers or a knock off of one. Thanks again guys!!!
Old 06-07-2020, 01:04 PM   #6
Glad it's working out for you. As for tire glue, It's been a long time since I've glued tires, but Zap-A-Gap CA tire glue always worked very well for me.
Help removing glued cut tires from wheel - Similar Threads
Removing glued tires buttercr125 Tires and Wheels 6 08-23-2012 09:34 AM
Removing glued tires? Kyle Hess Tires and Wheels 13 05-24-2007 07:09 PM
removing glued tires skrewdriver Tires and Wheels 12 01-14-2007 11:50 PM
