Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Cheap Chinese beadlock problems
Old 07-15-2018, 10:45 AM   #1
Default Cheap Chinese beadlock problems
Well, the title probably says it all, but Newbie user error is not unlikely.
I got the wheels on amazon (of course), good Px, seen them on similar rig as I am building ( Axial 10.2 Cherokee), but no joy mounting.
I can see how they should work and I also can understand the lock ring type of beadlock and how it works. it just looks to me as though this type of wheel is not as secure. is this a fair statement ?
I have checked the several "easy beadlock mounting" threads but no success yet.
I can see two possible basic problems here : Foam volume and the type of bead locking and where the locking pressure ( the bolts) is applied.
What I don't understand is whether or not the foam width (along the axel) plays a role. The OEM tire/foam (All-Terrain T/A) combination is quite a bit wider then the wheels when mated solidly. the tire bead just creeps out of the lock ONLY on the outer rim side. The outer rim does not have a nice square bite between the rim and the inner ring like the inner rim. Is it possible to have too much foam for this type of wheel to work properly ?
lasllcap@gmail.com is offline   Reply With Quote
Old 07-15-2018, 11:02 AM   #2
Default Re: Cheap Chinese beadlock problems
Perhaps it's the same issue some have had with RC4WD beadlocks with some tires like proline? I believe the fix in that case was a wider center ring.
Otherwise if it's just not easy to mount I've seen some use one longer screw to start the beadlock, work thr way around, then replace the 1 long screw with a standard screw.
Sent from my LGMP450 using Tapatalk
spoo76 is offline   Reply With Quote
Old 07-15-2018, 11:52 AM   #3
Never having seen anything like this before , it was the center ring that struck me as the way to deal with it. using a hub centered squeezer of some type may work but to me it would have to be incredibly even pressure at the rim edge to work in this case.
are center rings something that are available separately ??
Old 07-15-2018, 11:54 AM   #4
I glue my tires to the center ring and let it dry then i mount them ultra black rtv works realy good i also use e6000 in black depending what i have i have used super glue too just to make sure i keep the bead in place while mounting th3 tire the super glue dosent eeem to hold long term though you might try a little bit of glue on the outer beads also seeing as your having problems with them pulling off
ferp420 is offline   Reply With Quote
Old 07-15-2018, 12:41 PM   #5
Get a long enough m4 bolt/nut to use through the center and suck the two halves together. Remember to include the hub.
Brake Weight is offline   Reply With Quote
Old 07-15-2018, 01:25 PM   #6
Thanks for this , I will give it a try
Old 07-15-2018, 01:26 PM   #7
I am already getting this together, Thanks
Roger
Old 07-15-2018, 01:29 PM   #8
Wait aminute - What , are you guys on a beer break or something ? How come our not out crawlin around somewhere. Its Sunday right ?
Old 07-15-2018, 01:53 PM   #9
Just woke up actually. I drove 16 hours home after pulling a 13 hour last shift and figured I’d earned a 11 hour nap(coma). Gotta sort a few things around the house and should be wrenching in a few hours on a micro rock bouncer. LOL.
Old 07-15-2018, 09:36 PM   #10
I know right i only got 3 packs in today im slippin
Cheap Chinese beadlock problems - Similar Threads
cheap chinese 6x6 CM9000 Chit Chat 9 06-06-2016 06:28 PM
Problems with beadlock rims from eBay Nohabfsg Tires and Wheels 8 01-29-2015 06:02 PM
Axial beadlock Problems... biggin69 Axial AX-10 Scorpion 3 07-26-2008 06:57 PM
Beadlock problems! Prophecy Axial AX-10 Scorpion 9 10-20-2007 12:12 AM
