10-02-2018, 05:24 PM | #1 |
Newbie Join Date: Oct 2006 Location: akron
| Compound choices.
I'm trying to figure out what 1.9 tires I'd like to pick up and a few I am considering come in multiple compounds. Would there every be a reason to pick the less sticky/harder compound? Like buying G8 over Predator or Komp over Alien? This is for a trail truck specifically that sees a wide variety of terrain on a single outing if that makes any difference.
10-02-2018, 05:26 PM | #2 |
| Re: Compound choices.
Harder compounds will last longer.
10-02-2018, 06:13 PM | #3 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
Some people feel that in some designs the lugs fold over on the super soft compound instead of staying upright in a position that maximizes their grip. Most seem to prefer the sifter compounds though.
10-02-2018, 06:33 PM | #4 |
Harder compounds kill when it gets hot and turn to stone in the cold. On the flip side soft compounds are great in the cold but too soft and just fold up in the heat.
10-02-2018, 09:54 PM | #5 |
Beyond the temperature would terrain make a difference on which compound would be preferable?
10-03-2018, 06:03 AM | #6 |
Newbie Join Date: Mar 2017 Location: lakewood
On top of what was said I also noticed the softer compound works good for lighter vehicles and the stiffer compound works well with heavy vehicles Sent from my iPhone using Tapatalk |
10-03-2018, 06:10 AM | #7 |
Proline G8 is hard to beat for an all around compound that's both durable and performs well. G8 Hyrax will hang with the best tires from any other company in any compound in my experience. YMMV I have the new Predator compound Hyrax tires, but I haven't had a chance to use them yet. |
10-03-2018, 08:01 AM | #8 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
I recommend Pitbull Rock Beast Tires. They have consistently been used to win multiple scale competitions over the last five years. Pitbull tires have an actual bead lip that can be held by any bead lock. Proline Tires use a terrible slanted lip bead design that requires a special clamp ring or CA glue to hold.
10-03-2018, 09:06 AM | #9 | |
| Re: Compound choices. Quote:
Your statement about Proline tires is incorrect. Yes, the Proline tires have an odd bead design, but they will mount to most wheels without any special accommodations. People just lack the patience. Apparently, it can be impossible to mount the 2.2 XL tires, but everything else should work fine on most wheels. | |
10-03-2018, 01:05 PM | #10 | |
2.2 xl mount on anything if you actually try. And once they're mounted they're pretty much impossible to get off unless you want to. The bead is superior to any other manufacturer but it is different therefore scary. | |
10-03-2018, 02:05 PM | #11 |
Quarry Creeper Join Date: Dec 2011 Location: spokane
I'm running g8 rear and predator front with proline single stage foam and a thin layer of proline foam to fill the void and stiffen the tsl tires. My rig is 8lbs and it works good. The lugs on the predator do fold over easy but works good for pulling up stuff. I like both proline and pitbull but I do prefer the "odd" bead of the proline bc they hold tight. And proline are made in the 🇺🇸 so that's a seller for me too!! I often find that all the main brands work well. Some compounds work better on one part of the trail and some work better in others. So RWYB!!!
10-03-2018, 02:52 PM | #12 |
I'm actually debating between the Rock Beast XL, RC4WD MT/R's, and Proline KM3's or Krawlers. The KM3's are being released in the Predator compound and I was debating if I should wait on them. I have 1.55 Braven Berserkers on my TF2 and have been very happy with them but the price of the Rock Beasts are throwing me off so I started looking into other options. I'm leaning KM3's in G8 currently.
10-03-2018, 04:58 PM | #13 | |
10-08-2018, 05:45 PM | #14 |
Quarry Creeper Join Date: Feb 2016 Location: canada
So here it is finally got to try my 1.9 alien compound pitbull xors. It was a cold wet rainy day. Wet rocks ...... No issues im running stock foams which are hard as h€!! But they still grab. Mud... Turns into more of an axle hang up issue more then a tire issue. Overall climbing seems good enough mind you for the $100 price tag on these tires id expect them to be better for sure. I own the 2.2 version of the same tire and they are night and day different in softness flexibility. 2.2s are way softer and flex better. The 1.9s might just need a soft foam and some work in time. But for a first trip im impressed. Sent from my LG-M703 using Tapatalk |
10-10-2018, 03:37 PM | #15 | ||||
Agreed, I just can't stand the non-scale looks of the Hyrax, the smaller 1.9 isn't as bad looking though. ;) Quote:
Takes more work to mount Prolines and I use the specific lock rings, but yes can be pita, but doable. Quote:
Love the Proline 1.9 Kralwers G8 compound with their single stage foams on my TRX-4! They looks and work great! Pass on the new Proline compound tires imo. Love my Pitbull 1.55 Braven Berserkers on my TF2, looks and works great! | ||||
10-11-2018, 12:17 PM | #16 |
| Re: Compound choices. Whatever I decide on will also be going on a TRX-4. I'm fairly confident if i got the proline route I'll be sticking with the G8 compound. I don't have much in the way of dry rock to crawl on. Most of the places I run I deal with dirt/mud and tree roots.
Compound choices. - Similar Threads | ||||
what to do choices? | savage6969 | Axial SCX-10 | 7 | 06-28-2010 04:01 PM |
Choices.... | Col. Sanders | Tires and Wheels | 22 | 09-23-2009 02:09 PM |
2.2 choices | racerrandy | General Crawlers | 8 | 11-26-2007 11:12 PM |
