10-20-2018, 04:24 PM | #1 |
Newbie Join Date: Jun 2018 Location: Bracebridge
| 4.19 KLR MTX vs MT vs AT
I am building a tube frame rock crawler and will end up around 9 to 10 pounds. I know I want to run some 4.19 KLR tires but not sure which of the three will work best. I run about 90% of the time on granite. Has anyone run these on granite and which would you recommend? |
10-21-2018, 09:17 AM | #2 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
| Re: 4.19 KLR MTX vs MT vs AT
Proline hyrax predator compound. https://www.prolineracing.com/tires/...ruck-tires.asp Next question is, what foams? |
10-21-2018, 10:34 AM | #3 | |
| Re: 4.19 KLR MTX vs MT vs AT Quote:
I will only run KLR or Pitbull. | |
10-21-2018, 05:26 PM | #4 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
I have ran 4.19 KLR MTs on granite quite a bit. Ran the inner stage only of the 4.5 CI two stage foams. The MTs worked fine for me. The MTX only has slightly more lug spacing and a bit more siping if I remember right.
10-22-2018, 09:36 AM | #5 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
From experience running a less aggressive tread/lug pattern works much better on high traction surfaces. Aggressive tread/lugs naturally cause up and down movement. I know the movement is minimal but a smoother pattern keeps your tires planted smooth.... Let the compound do the work... Hope my gibberish makes since..
10-22-2018, 11:05 AM | #6 | ||
Pitbull now has some 4.19" tires. Did you consider those? Quote:
4.19 KLR MTX vs MT vs AT - Similar Threads | ||||
MSTs new MTX-1 | CrawlinMike | Mega/Monster Trucks | 37 | 12-13-2020 04:28 PM |
Soze picks up a MTX-1 | soze | Mega/Monster Trucks | 24 | 09-01-2019 06:26 PM |
Mst mtx-1 | casper975 | Newbie General | 2 | 12-30-2017 01:10 AM |
