12-22-2018, 09:38 AM | #1 |
Newbie Join Date: Dec 2018 Location: WV
| Proline Hyrax wobble
I recently picked up a set of proline hyrax G8 1.9 premounted on proline impulse internal bead-locks. Problem is, when mounted three of the tires are crooked and wobble back and forth. I did remove one bead lock and remounted, but it’s still crooked. I did not pull the foam out. Anyone else run into something like this? Will they self correct over time? Ideas? |
12-22-2018, 09:49 AM | #2 |
| Re: Proline Hyrax wobble
The foam is probably not perfectly straight. Common with most all premounts. I recomend massaging the foam through the tire to work it even... I did tis on my stock Honcho tires correcting the worst of the wobbles. The rest settled out.
Proline Hyrax wobble - Similar Threads | ||||
Proline Hyrax 2.2 Question | magic_yeti | Tires and Wheels | 12 | 10-14-2019 01:07 PM |
Proline Hyrax Predator 1.9 | Ethan503 | Tires and Wheels | 1 | 05-15-2018 05:03 PM |
proline hyrax 1.9 any new updates? | fomoco | Tires and Wheels | 14 | 07-09-2017 12:34 PM |
Proline Hyrax Lug cut ?? | steamboatbob | Tires and Wheels | 24 | 06-29-2017 02:48 AM |
