02-09-2019, 07:14 AM | #1 |
Pebble Pounder Join Date: Feb 2012 Location: Boomer
| Ssd wheels
Will these wheels bolt directly to the Trx 4 or will I need different hexes? *1.9" Double Time Beadlock Wheels |
02-09-2019, 07:18 AM | #2 |
| Re: Ssd wheels
They will bolt on no problem!
02-09-2019, 01:13 PM | #3 |
Rock Crawler Join Date: Dec 2005 Location: East Texas
| Re: Ssd wheels
Hex wise you wont have an issue. I would just be cautious of the inside ring bolts. it looks like they are flush with the rear of wheel? If so your portals will most likely hit unless its offset enough to keep the portal out of the wheel. I am not positive as I dont have these. Just something to look for as I tried a bunch of wheels until I found one I liked. But that was a common issue, so just be aware. |
02-11-2019, 07:00 AM | #4 | |
| Re: Ssd wheels Quote:
02-11-2019, 07:05 AM | #5 |
| Re: Ssd wheels
I noticed they have them mounted on a trx4 in these pics..Scroll down to the bottom. PARTS FOR TRX-412mm Aluminum Hex Set for TRX-4 But I cant tell if the ssd portal cover weights are mounted in that pic.. |
02-11-2019, 08:20 AM | #6 | |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
Regarding the hexes you don’t “need” them but those wheels will fit better and tighter at the hex if you have them. The TRX4 stock hex is completely flat and m the outside. These wheels you’ll notice have a little raised ring part at the very center on top of the hex. With the SSD hexes there is a step, for lack of a better term, on the hex that fits into the indentation on the wheel hub and offers a tighter fit. If you haven’t already ordered some I’d also recommend getting some of the ssd scale locking hubs (and the corresponding tool) as they’ll finish off the look of the wheel proper. Last edited by Topher Builds; 02-11-2019 at 09:43 AM. | |
02-11-2019, 11:11 AM | #7 | |
02-20-2019, 02:46 PM | #8 |
| Re: Ssd wheels
These wheels do fit the stock portals on the trx4. But the ssd brass portal covers require a couple mm dremeled down. Wasnt an issue really..
02-22-2019, 04:37 PM | #9 |
| Re: Ssd wheels |
04-19-2019, 03:56 PM | #10 |
Quarry Creeper Join Date: Mar 2019 Location: Low CG
| Re: Ssd wheels
I don't understand how you guys can say that SSD wheels on the TRX4 are a direct fit and that the SSD hexes aren't needed. This is my second set of SSD wheels that I've attempted to mount my Canyon Trail tires on. With the first set, I struggled to get the two wheel halves together. Then I found out from SSD, that these were a set of their "older wheels" and the hole in the hub was to small to fit the 5mm TRX4 axle! I didn't want to get new hubs or drill the hole out so I figured I'd sell them at some point. I then bought another set of SSD wheels and after getting the Canyon Trails mounted, the tires just didn't look right. Frustrated, I just said whatever and attempted to mount them on the chassis. Well, they don't fit on the stock hexes properly. The hole in the wheel is huge and the wheel wobbles around on the hex! It is very obvious to me that you do in fact need the SSD 12mm hexes on the TRX4 for a proper and solid fit. This problem on top of the fact that these wheels simply do not work well with the Canyon Trails, has left me very unhappy with my two SSD experiences. By contrast, I have a set of the cheapest Pro-Line plastic beadlock wheels you can buy. They go together effortlessly, fit the tires perfectly, and match the axle and hex without any problems! |
04-19-2019, 04:16 PM | #11 | |
Quarry Creeper Join Date: Jun 2016 Location: Tacoma
04-19-2019, 04:31 PM | #12 | |
I first got these - RC D Hole 1.9" Steel Beadlock Crawler Wheels Then these - Rock Racers The Rock Racers are a bit wider and the tire now rubs the portal cover. Hopefully, the larger SSD hexes will also provide some offset. Even then, I'll have to figure out why the tires are just not fitting the wheels right. | |
04-21-2019, 02:02 PM | #13 |
RCC Addict Join Date: Jun 2016 Location: Germany
| Re: Ssd wheels
I have SSD rock racers on my TRex with hyrax and .475 slw Hubs using the SSD trx-4 Hex with no issues. Have Brass Portal Covers and Weights installed. Gesendet von meinem Pixel 2 XL mit Tapatalk |
04-25-2019, 05:52 AM | #14 |
| Re: Ssd wheels When I mounted the Rock Racers on my Canyon Trails, the front tires rubbed the top of the portal housing. The Rock Racers are wider than most other wheels and also have less offset. Apparently, the .475 SLW hubs make up for that difference. The only thing that I don't like about the .475 hubs is that increase in track width which is not always desirable. Thanks for the info!
04-28-2019, 04:46 PM | #15 |
Rock Crawler Join Date: Jun 2009 Location: UK
| Re: Ssd wheels
Couldn't agree more. SSD wheels are the only 'inner ring' beadlocks that I'd use. After struggling with RC4WD wheels. and some others in the past i was reluctant to try SSD's. But i have to say they were quicker and easier to mount tires on than any of the 'dual' ringed wheels I've used in the past. |
Ssd wheels - Similar Threads | ||||
ssd rc contender wheels based on trd wheels? | rockhopper2 | Tires and Wheels | 9 | 10-25-2018 01:44 AM |
New SSD 2.2 Proline Rings for SSD wheels | SSD | Tires and Wheels | 32 | 02-07-2017 10:56 PM |
Race line Monster Wheels or SSD-RC Assassin wheels | rckjeep | Tires and Wheels | 9 | 07-24-2016 06:30 PM |
SSD wheels and SSD knuckle interference? | skybolt | Tires and Wheels | 7 | 02-13-2016 02:56 AM |
