02-21-2019, 01:37 PM | #1 |
Rock Stacker Join Date: Jul 2006 Location: moab
| hyrax predator compound review
This is not going to be a real in depth review but it will have some information that I would've loved to find before purchasing these tires. This is again for the Proline 1.9 Hyrax Predator compound. I'm running the tires on proline dual stage foams which seem great. I installed these tires in December and have about 10 packs or 15 hours of drive time on them. The first 3 packs I ran through them left me a little underwhelmed. The Traxxas canyon tires were what I had been using prior and really there didn't seem to be any benefits through the first few packs. Shortly after that the tires started to break in and break down and that's when they really starting grabbing. I live in Moab so all I'm driving on is slickrock but if the rock is dry and clean I'd put these tires up against any tire out there. The grip level is insane once they get worn in both forward and to the side. I have only two knocks on these tires that are also what makes them great. First these tires do not clear out worth a damn which I'm sure is because the sticky compound and all the sipping. If you run through wet sand, dirt or mud plan on your tires being caked for well after all your buddies tires are fully clean and clear. The second knock is the durability which I get is going to be shortened due to the softer compound. Like I said I have about 15 hours of drive time on these tires and well you can see in the photos how much break down there is. My overall assessment for these tires is if you want the best performing tire out there maybe to use in dry clean comps or you're just a performance junky like myself then these are the tire for you however if you are looking for a good all around tire that will last more than 1 winter season (I cant even imagine how quick these would burn up out on the rocks in the triple digit heat) then maybe look elsewhere. Hope this is helpful. |
02-21-2019, 11:44 PM | #2 |
Quarry Creeper Join Date: Jan 2016 Location: Boulder
| Re: hyrax predator compound review
This is a very informative review. Thank you for the words and the pictures - especially that close up of the wear.
02-22-2019, 11:08 PM | #3 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
Thanks for the first hand info! Sounds about how I guessed. I have a set of the 4.19's in predator that I need to run. Again, thanks for the info. Also, a few questions about your rig that relate to tire wear if you don't mind. Curious to know how much your rig weighs, if it's overdriven and weight bias (front heavy or fairly neutral). Thanks!
02-23-2019, 08:26 AM | #4 |
Quarry Creeper Join Date: Nov 2015 Location: US
How are they with dust? I was talking about them last night with someone and he was concerned that the sticky compound would pick up too much dust. Your pictures do not reflect that but our indoor course definitely gets dusty and I notice that effect after crawling indoors. I feel like outside won't be as bad
02-25-2019, 09:06 AM | #5 | |
| Re: hyrax predator compound review Quote:
02-25-2019, 09:07 AM | #6 | |
03-25-2019, 06:34 PM | #7 |
Update: 15 battery packs through them and they are mostly gone and are now performing worse then most regular trail tires.
03-25-2019, 08:40 PM | #8 |
Rock Crawler Join Date: Dec 2018 Location: Ontario, Canada
Thanks for the update! Any idea what you will be installing next? Sent from my iPhone using Tapatalk |
03-26-2019, 06:07 AM | #9 |
Newbie Join Date: Feb 2019 Location: Central Maine
Thanks for the review. Surprised how quick they break down. I guess thats the trade off for performance.
03-26-2019, 06:13 AM | #10 |
Those rocks look like they would destroy any tire. So much traction! I envy that. I have a set of Hyrax tires in Predator flavor that will be going on my TRX-4 Sport build. I expect that they have a much longer life here on the east coast. What kind of power (battery, ESC and motor) are in the rig running these tires? |
03-26-2019, 07:22 AM | #11 |
Mostly gone? Those are just getting broke in to run on the rocks now. I've been eyeballing some sx's in predator but they changed the mold to make the lugs so shallow I'm not sure it's worth messing with. |
03-26-2019, 07:38 AM | #12 |
| Re: hyrax predator compound review WTF? I hadn't noticed they did that. That change, alone, seems like it would reduce the effectiveness of TSLs.
03-26-2019, 08:24 AM | #13 | |
When bfg krawlers came out 20 years ago they sold a half tread version that was supposed to be better since krawlers have always gotten better with use so these were supposed to be good new. Marketing nonsense that sold more tires. krawlers get better because the carcass breaks in and the lugs wear down a bit for increased contact. Watch for the pro line marketing department to spin it when people complain. | |
03-26-2019, 08:24 AM | #14 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
Wow, what kind of driving do you do? Lots of wheel speed? I couldn’t remember when I bought my Predator hyrax. Had to search the email and found out I got them in July of last year. Ran lots of 3S packs through, on 3 different trucks, and here’s how they sit now. |
03-26-2019, 09:52 AM | #15 | ||
03-26-2019, 11:20 AM | #16 |
RCC Addict Join Date: Sep 2014 Location: Alberta
| Re: hyrax predator compound review |
03-26-2019, 12:17 PM | #17 |
03-26-2019, 12:19 PM | #18 | |
03-26-2019, 12:23 PM | #19 |
03-26-2019, 12:30 PM | #20 | |
hyrax predator compound review - Similar Threads | ||||
Proline Hyrax G8 or Predator? Need help! | Insanehobbies | Traxxas TRX-4 | 17 | 01-22-2019 08:25 AM |
IN STOCK NOW the NEW Pro-Line Racing 4.19 Class Hyrax Predator Tires! | RPP Hobby | RPP Hobby | 0 | 01-10-2019 12:19 PM |
Coming SOON the NEW Pro-Line Racing 4.19 Class Hyrax Predator Tires! | RPP Hobby | RPP Hobby | 0 | 12-14-2018 11:08 AM |
RESTOCK Pro-Line Racing 1.9 Hyrax Predator!! | RPP Hobby | RPP Hobby | 0 | 07-13-2018 10:47 AM |
Proline Hyrax Predator 1.9 | Ethan503 | Tires and Wheels | 1 | 05-15-2018 05:03 PM |
