07-28-2019, 08:51 AM | #21 |
RCC Addict Join Date: Feb 2017 Location: Surprise
| Re: Why Proline, Why ?
At 6:15 give or take Harley is running these wheels..... https://youtu.be/BwSDUucjkeI |
07-28-2019, 09:44 AM | #22 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
They don’t look like they do too bad. Seems like less tread flex than a dual stage foam but that may not hurt it. I’d like to see them doing some slower/less wheel-speed climbs, definitely have my attention thus far. |
07-28-2019, 09:55 AM | #23 |
Personally I don't think they will have the tread deformation needed for ultimate traction compared to regular tires, but they will possibly be great for higher speeds...
07-28-2019, 10:12 AM | #24 |
make these a tire insert and its gold insert these inside a normal tire for the best of all worlds this is what ive been working on for years my proto types are extremely crude and dident work well the best i could come up with i moved on to tire in tire but its the same basic idea that i had these could even be 3d printed with flexable fillament with different webing paterns for more or less suport its about time there moving away from foams #gofoamless |
07-28-2019, 11:17 AM | #25 |
Well the simple answer is these do work.... Josh said he wouldn't comp with them, but they do work. I like the idea as a trail tire, foams be damned!!
09-15-2019, 04:20 PM | #26 |
Rock Crawler Join Date: Mar 2019 Location: Terrassa
| Re: Why Proline, Why ? |
09-15-2019, 08:45 PM | #27 |
Rock Crawler Join Date: Feb 2012 Location: Michigan
09-15-2019, 11:52 PM | #28 |
Quarry Creeper Join Date: Mar 2018 Location: Indonesia
I think the future is closed cell foams with cross holes like somebody posted as being available in Germany. Possibly do the outer part with circumferential grooves like the CI closed cell foams and maybe even some star cuts if necessary then add different sized and positioned holes to soften them some more. Sent from my LG-H870DS using Tapatalk Last edited by bbrigg; 09-16-2019 at 03:09 AM. |
09-16-2019, 06:28 AM | #29 | |
| Re: Why Proline, Why ? Quote:
I certainly hope we get rid of open cell foams at some point. And dual stage foams, while having good performance, are a PITA to insert into a tire and get lined up. | |
09-16-2019, 06:44 AM | #30 |
I wouldn't be so quick to call the star cut stupid. It won plenty of comps back in the days when only single stage foams were available. Be that as it may, perhaps I should have been clearer. More of a modified star with much shallower grooves just a little more pronounced than the ones in the image. That would likely help lighter rigs. After all, having a more deformable outer section is the basis for the most highly regarded foams currently available. I do agree that the placement, size and even shape of the lateral holes would be the biggest factor. Some experimentation with this, in conjunction with the far more flexible outer portion due to the grooves, could give us performance equal to triple stage foams. Having used both the Pro-Line and CI closed cell foams the circumferential grooves absolutely need to be there to "soften" the outer part. I can't see lateral holes doing as well. Sent from my LG-H870DS using Tapatalk |
09-16-2019, 07:59 AM | #31 | |
09-16-2019, 08:24 AM | #32 |
09-16-2019, 09:53 AM | #33 |
09-16-2019, 12:31 PM | #34 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
| Re: Why Proline, Why ? Yeah, I hate putting two stage foams in...damn things never seem to be perfect. The holes drilled into closed cell foams looks like it could be great.
09-16-2019, 02:50 PM | #35 | ||
X2. | ||
Why Proline, Why ? - Similar Threads | ||||
Yokohama Geolandar with Proline Titus 2.2 on SCX10/Proline 74' Bronco | FreedomRiding | Tires and Wheels | 0 | 06-25-2012 03:26 PM |
