Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Buying foams online
Old 10-15-2019, 02:30 PM   #1
Default Buying foams online
Not having the ability to go to a hobby shop near by and personally feeling foams for tires, how do you guys know what’s going to be what your after? I love the internet but how do you make sure your getting what your after...
yotadude77 is offline   Reply With Quote
Old 10-15-2019, 02:35 PM   #2
Default Re: Buying foams online
I weigh my rig and go from there. Crawler innovations shows what foams to use for what weight. My rig is approx 10 pounds and their recommendation is med dual stage up front and firm dual stage in rear. And they made a major difference in handling compared to the stock foams
Sent from someplace in hell using Tapatalk
freakofnature is offline   Reply With Quote
Old 10-17-2019, 06:18 AM   #3
Quite easy, as I'm not a foam specialist. However Eddie who is CI, will gladly send you his recommendations and they usually work perfect.
PM him with all you info, weight, tires, power, use. He will tell you which will work best with you combo. Ive found his tips to be the best around.
RC Crawler Foams, Car Stands, Bike Foams and More by Crawler Innovations
Foams do not need to be confusing!
Here are some basics you need to know...
#1. The Crawler Innovations Double Deuce, Lil Nova and Deuce’s Wild Foam Systems are based on the weight and intended use of the your RC Vehicle, not the overall height of the tire.
#2. The closed cell foam is water proof, and air tight. The tire must be vented to allow the foam and the tire to properly conform to the rock surface. No air movement = No tire conformity
#3. Crawler Innovations always recommends stepping up one outer density for the rear foam pair of your RC Vehicle. The reason being is that the weight of the RC vehicle transfers to the rear tires on a climb.
#4. There is no one magical foam that does it all. If you want maximum rock crawling traction, you need a Dual Stage foam. If you want maximum speed with no tire enlargement, you need a Deuce's Wild Single Stage. Crawler Innovations offers a number of tuning aids that will allow you to finely tune your foams, once you've reached that level of understanding. Not everyone wants to be a Pro RC driver, some are happy weekend warriors.
#5. Wheel Weights: Crawler Innovations highly recommends knuckle weights. Do your best to keep rotating weight off your RC vehicle drive train. Your RC vehicle will last longer, perform better, and you can use the saved money from non broken drive train parts for other upgrades.
However, if you do use stick on lead weight around your RC rim, all of the Crawler Innovations Closed Cell Inner Foams will need to be modified to clear your wheel weights without stretching the inner. When you stretch the inner, it increases the Outside Diameter and the foam does not perform as designed. A Dremel with a sanding drum makes quick work of modifying the foam.
#6. Narrow Wheels with Standard Foams. If you have a Dremel with a sanding drum, sand the Closed Cell inner foam at a 45 degree angle so that it matches the width of your clamp ring. All of the VP bead locks are .750" width clamp rings, 1" overall. C.I. sells narrow inner foams, but unless your tire is narrowed, it's not properly filling the tire.
#7. Dual Stage Foams and Water: It's a non-issue, even with the tires vented. The closed cell foam PUSHES water away. So even though water might be coming through a 2mm vent hole, only the outer will retain water, but the outer is being flattened as it is being rolled on, thereby, only a minimal amount of water is even allowed in the tire. At the end of your day of fun, simply hand squeeze out as much water as possible from your tires, then run the RC Vehicle at wide open throttle with the vehicle in a elevated position and the centrifugal force will pull most of the remaining water out through the vent holes. Store your RC vehicle in an elevated position to avoid flat spots in the tires and foams.
Outer Densities: White foam / No markings = Soft Orange dot = Medium Black dot = Firm
mikemcE is offline   Reply With Quote
Old 10-18-2019, 02:28 PM   #4
Great info...thanks!
Buying foams online - Similar Threads
Anyone got experience buying ammo online? nascarkeith Chit Chat 7 12-22-2010 05:42 PM
Buying RTR vs Buying Parts Tonelock Axial AX-10 Scorpion 20 10-03-2008 07:09 PM
buying small pets online? trickedoutTLT06 Chit Chat 28 07-13-2007 01:18 PM
