11-04-2019, 01:10 PM | #1 |
Quarry Creeper Join Date: Nov 2018 Location: 🌎
| Wheel axle holes so oversized! Why????
I have been looking for another set of aluminum bead lock wheels and most of the ones I am seeing have a 6.7mm hole for the axle. Why is the axle mounting hole so large? That is much larger then the standard crawler axle. Example: Last edited by Stomp; 11-04-2019 at 01:27 PM. |
11-04-2019, 01:14 PM | #2 |
| Re: Wheel axle holes so oversized! Why????
Because those use an slw type hub that can be used with a stepped ar60 type hex.
11-04-2019, 01:23 PM | #3 |
Thanks for the quick reply. So if I were to get a set of wheels like this I would need new hex's and possibly a nut with a flange?
11-04-2019, 02:13 PM | #4 | |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
| Re: Wheel axle holes so oversized! Why???? Quote:
The wheel hex does 70% of the centering so I'd run them as is. I've currently got 2 sets of wheels running this way and they're completely fine. You can get away with a lot on crawler/trail rigs that's technically not ideal but at the speeds these things move they aren't really a problem. | |
11-04-2019, 05:24 PM | #5 |
Yeah it works without using an Axial stepped hex but I sure wish we could get away from the giant holes. I run a lot of scale hubs and if you tighten them down without using a slightly larger washer the locknut gets pulled out of the scale hub (SSD hubs). We can all thank Axial for these giant holes |
11-04-2019, 05:37 PM | #6 |
| Re: Wheel axle holes so oversized! Why???? |
11-04-2019, 07:12 PM | #7 |
Got it, thanks
11-04-2019, 08:11 PM | #8 |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
| Re: Wheel axle holes so oversized! Why???? Actually, you can thank HPI for that one. Since a lot of the first axial crawler (Scorpion) parts were carry overs from HPI bits, and correct me if I'm wrong, I think one of the dudes that started Axial left HPI to do so, therefore a lot of the parts were identical. Ring and pinion diff carriers etc were all the same, hexes all the same, plastics.... uh, yeah... the same.... garbage back in the 2006-7 day. |
11-07-2019, 05:37 PM | #9 | |
11-07-2019, 05:42 PM | #10 |
Interesting, Thanks Paul! Hey hows that crazy Ascender build coming? |
Wheel axle holes so oversized! Why???? - Similar Threads | ||||
Holes in front axle | SerpentCT4S | Axial SCX-10 | 20 | 07-29-2014 06:26 PM |
Extended EXT+15mm Wheel Hub & Wheel Axle for AX10 C22819 | alvaroguisso | Axial AX-10 Scorpion | 6 | 09-21-2012 05:51 PM |
Wheel Air Holes | Knarly Nerd | Tires and Wheels | 43 | 03-31-2012 08:55 AM |
Looking for the Robby Gordon wheel 6 "D" holes non beadlock plastic | toy4crawlin | General Crawlers | 3 | 12-02-2009 09:54 AM |
