02-19-2021, 04:18 PM | #141 |
| Re: Landmines 1.9
Can you find the A.L.T. foams there in Spain? I think they are German, highly recommended, and they specify stiffness and sizes... https://www.rc-hp.de/19-Zoll_1 |
02-19-2021, 05:25 PM | #142 |
| Re: Landmines 1.9 Based on the weight I dont know, I assume you meant 2.1 kg? Personally I like to undersize the foams by 1/4" (6.4mm) from the tire O.D. or undersize them even more for more compliance. I just setup some 4 3/4" (120mm) Landmines with 4 1/4" (108mm) foams on a 2.64 kg rig and they're performing well. I use CI foams with soft outers up front and mediums in back. As was mentioned earlier this compound doesn't seem to like wet rock. I'm used to the G8 and predator compounds from Proline not caring if its wet out or not. |
03-23-2021, 03:38 PM | #143 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
| Re: Landmines 1.9
Tested them this weekend on the vs410 pro and they did very well. They will definitely be staying on this truck since they kinda look like the mickey Thompson Baja boss tires on my JLU.
03-23-2021, 05:03 PM | #144 |
Quarry Creeper Join Date: Dec 2012 Location: okc
| Re: Landmines 1.9
I got a set of the 4.19 class 1 size to try. will give them a good test in the next couple of weeks, they are really sticky out of the package and I think the foam will be right for my truck
03-28-2021, 05:47 PM | #145 |
| Re: Landmines 1.9
ran the class 1 landmines today, we were crawling on really hard sandstone that really good bite, the class 1 landmines were great. the only tire that was better today was my 4.75 class 2 proline Trenchers. was running the landmines on a class 1 Lcg truck
03-28-2021, 05:50 PM | #146 | |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
| Re: Landmines 1.9 Quote:
Sent from my SM-T500 using Tapatalk Last edited by MaX-D; 03-28-2021 at 08:01 PM. | |
03-28-2021, 06:24 PM | #147 |
| Re: Landmines 1.9
Been running my 4.75 Landmines in the Green compound either VooDoo Halo Foams on my G-Speed V3 rig and I’ve been extremely happy with their performance. That said, I really want to try a set of Trenchers in Predator! 😈 |
04-01-2021, 08:39 PM | #148 |
| Re: Landmines 1.9
I am having great luck with the Trencher on hard sand stone and rocks, it does NOT like dirt it packs up and doesn't clean it's self out very well, the proline Krawler T/A is the best dirt tire and maybe best all around tire in my area
04-01-2021, 09:23 PM | #149 |
| Re: Landmines 1.9
I have predator trenchers, predator sx's, predator krawlers and green landmines. All are 4.75" and other than the krawlers being 4.25" soft/non comp front and medium 4.25" comp cut rear they're all 4.5" same otherwise combo. The krawlers are my go too hands down simply because they're beat up from the street up so they grip like crazy. The landmines are a close second. I like them a helluva lot more than I expected to. |
