12-09-2019, 07:33 AM | #1 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
| 1.55 foams for a light weight Barrage with MT/Rs?
Anybody have recommendations for foams for a set of 1.55 RC4WD MT/R tires on a stock-ish Barrage? The biggest issue I've run into on the Barrage with the couple sets of tires that I've had on it so far is that even with the super cheap stock foams, the tires are too firm to compress because the truck is so light. Since most tires, even the 1.55s, are designed for larger (and heavier) trucks, I'm concerned that any foams are going to be too firm for my application. CI has the CWR-2007 1.55 Lil Novas with the soft outer foam, but because they're labeled as being for 3.5-3.75" tall tires, I'm a bit concerned that they may still fill the tire too much for it to stay soft. I ran into this using the 4.5" Lil Novas on my Gen8. Does anybody have experience with foams in a 1.55 on the smaller 1/12 trucks? Maybe some guys with the 1.55 CR12 trucks can chime in? |
12-09-2019, 07:55 AM | #2 |
| Re: 1.55 foams for a light weight Barrage with MT/Rs?
CI has single stage 1.55 inserts that should do the trick. Lil' Nova Single Stage 1.55 The description says they are good for trucks around 3lbs. |
12-09-2019, 10:06 AM | #3 | |
| Re: 1.55 foams for a light weight Barrage with MT/Rs? Quote:
1.55 foams for a light weight Barrage with MT/Rs? - Similar Threads | ||||
Foams for light weight rigs | sally1800 | Tires and Wheels | 29 | 04-25-2013 07:18 AM |
Drilled Light Weight RC4WD Gears vs. Axial Light weight gears. | OFFROADRCKOREA | Axial XR10 | 1 | 12-12-2012 08:10 PM |
Light Weight Rigs | jlsandkes | Axial XR10 | 11 | 06-01-2012 10:01 AM |
