Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: trx4 traxx?
Old 01-30-2020, 11:18 AM   #1
Default trx4 traxx?
does anyone have any reviews on them before I buy them. are they worth it? does anyone have some insight?
Sent from my SM-N960U using Tapatalk
damnitbubbles is offline   Reply With Quote
Old 01-30-2020, 12:40 PM   #2
Default Re: trx4 traxx?
Go to youtube and do a search for Traxxas Traxx. Literally pages and pages of video reviews.
Inspector86 is offline   Reply With Quote
Old 01-30-2020, 02:17 PM   #3
Slow is the new Fast
smog's Avatar
I have two sets I like them so much. My kid and I have been running them in the snow this winter. They require some care and maintenance to keep them in good condition, but there is a lot more to them than a set of tires so no surprises there.What kind of information are you after?
In my opinion they are designed and perform really well, a least in winter. I would never consider taking them out over the rocks. The tracks lack the benefits you get from foam-tuning your tires.
Here is a link to some running video I took of them
https://youtu.be/F3usvlKVo30
smog is offline   Reply With Quote
Old 01-30-2020, 02:55 PM   #4
Moderator
JatoTheRipper's Avatar
I bought a set. Went to install them and only then realized they won't work with SSD portal weights. I stopped their. I'm not removing the portal weights so I either have to modify the Traxx shock mounts or create my own.
Old 01-30-2020, 05:57 PM   #5
what type of maintenance do they require?
Old 01-30-2020, 06:30 PM   #6
I think the traxx for the TRX4 out performed tires in deep snow (six to eight inches),but theirs alot of rolling resistance and put a strain on the motor and E.S.C.
jcanuck is offline   Reply With Quote
Old 01-30-2020, 09:57 PM   #7
smog's Avatar
The bushings and bearings need to be oiled if you are getting them wet. It’s simple, but needs to be done so they continue running smoothly.
Rolling resistance? They aren’t designed to roll dude. The contact patch is a large flat surface.
Old 01-30-2020, 09:58 PM   #8
what type of oil do you use
Old 01-30-2020, 10:21 PM   #9
Alot of moving parts and possible the traxx being new could be a cause of this.But traxxas highly suggest using only using the low gear in the two speed. As for maintenance Traxxas recommends clearing off mud and water with compressed air and also spraying wd40 on the metal parts/bushings of the of the traxx
Old 01-31-2020, 06:48 AM   #10
Moderator
Yeah there's more drag in the Traxx than you have with tires. That's why Traxxas has a big, bright yellow sheet taped to the inner packaging that states you must pay attention to your gearing.
Old 02-01-2020, 03:52 PM   #11
update. I picked some up and I haven't been disappointed! I realized that my rear diff lock had broken so I went to my local shop and picked up some permanently locked diff spools, and they work so great! the mounting is a hassle though, I'm sad I cant just slap them on and if I wanted to while on the trail slap on my tires. I've had my trx4 for about a month now and it just keeps on delivering new and amazing suprise. by far the beat crawler I've physically witnessed. sure I've sunk about 1,800$ into it but I'm not disappointed or unimpressed at all!
trx4 traxx? - Similar Threads
Looking for a suggestion modded TRX4 Traxx or Gen8 Axe BA0701 General Crawlers 1 01-15-2020 09:06 AM
Yeti Traxx! little squirt Axial Yeti 3 07-17-2015 10:14 PM
Thunder Traxx THE CRAWLER KING Non Crawler RC's 22 11-25-2009 03:51 PM
gaint traxx $45 blazed Chit Chat 0 04-07-2006 11:49 PM
