Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: What size hubs ???
Old 02-07-2020, 01:07 PM   #1
Default What size hubs ???
I recently picked up some used Vanquish OMF 2.2s, which came with SLW hubs already attached. Unfortunately, there's no markings to indicate their size. Total thickness, including the wheel 'nub', is 14.5mm. Without the 'nub', they're approx 12.25mm. They're too thick to be 350s, and they're too thin to be 725s. Can anyone please tell me which SLW hubs these are?
~ More peace, love, laughter & kindness would make the world a MUCH better place
Panther6834 is offline   Reply With Quote
Old 02-07-2020, 02:19 PM   #2
Default Re: What size hubs ???
I believe slw hubs are measured from the backside edge to the wheel mounting surface (NOT including the "nub", measured in thousandths of an inch) so a .475 would be 12.065mm, sounds like what you've got. .600's would be 15.24mm by the same method.
Are the lug holes threaded 4-40? Most (all?) of the Chinese knockoffs are threaded m3 or even m2.5, so their measurements probably won't match up perfectly with the genuine article (which annoyingly uses 4-40.)
TheLetterJ is offline   Reply With Quote
Old 02-07-2020, 05:47 PM   #3
They're 4-40...not knockoffs. After cleaning them up, disassembling them, painting the screws that'll go into the "decorative" holes, swapping the original black beadlock rings for blue,and putting them back together, here's what they're looking like.
What size hubs ??? - Similar Threads
ci wheels - which size hubs? stimpy Axial AX-10 Scorpion 4 01-30-2016 03:47 AM
What size vp hubs do I need? throttlejock27 Axial Wraith 9 03-30-2013 03:35 PM
What size Mayhem Hubs? 4ONDFLR Axial Wraith 8 03-30-2013 02:32 PM
What size hubs??? msd44 Tires and Wheels 4 09-07-2012 12:40 PM
What size of vp hubs ax10tn Axial Wraith 3 01-29-2012 09:50 AM
