02-11-2020, 06:59 AM | #1 |
Quarry Creeper Join Date: Dec 2015 Location: NY
| Scale hardware for “Chanquish” wheels & VP style hubs?
Recently purchased some LURC M3 scale bolts for my “Chanquish” wheels and quickly realized they won’t work. The holes in the wheel are too tight for the bolt and tool as seen below: The only solution I can think of is switching to Vanquish hubs and using LURC 4-40 acorn nuts. (As suggested on their website) Anyone have another solution??? Sent from my iPhone using Tapatalk |
02-11-2020, 07:30 AM | #2 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
| Re: Scale hardware for “Chanquish” wheels & VP style hubs?
Nope. VP Hubs and the 4-40 Acorns is exactly what I would do. Plus the acorns look better as lug nuts.
02-11-2020, 07:30 AM | #3 |
LockedUP makes these specific screws to fit in those recesses on Vanquish wheels. Notice they require a 2.5mm nut driver. The other versions of this hardware that require a 3mm nut driver won't work. 4-40 x .25" FLANGE Acorn Wheel Studs |
02-11-2020, 07:55 AM | #4 |
Good info guys! ARE the hubs interchangeable? I didn’t even think of asking... EDIT: Jato - Found your response to another thread, and the PCD should be the same. so NOW for 2 sets of wheels id have to spend $65 just on SLW hubs... What the hell... Last edited by VR6 BeelzeDub; 02-11-2020 at 09:37 AM. |
02-11-2020, 09:59 AM | #5 |
So I found these on Amazon. (Basic Asian hubs that my wheels came with) except read the middle part about “available for SLW hubs” and using 4-40 hardware? Sent from my iPhone using Tapatalk |
02-11-2020, 10:16 AM | #6 |
| Re: Scale hardware for “Chanquish” wheels & VP style hubs? I believe M3 will thread into 4-40 and vice versa. It may just screw up the threads, but if it's once and done, with some thread lock, it should be fine.
02-11-2020, 10:24 AM | #7 |
RCC Addict Join Date: Sep 2014 Location: Alberta
I've used 4-40 scale lugs in the no-name SLW hubs before. They are a bit tight the first go but then easy. It has never been a problem for me.
02-11-2020, 11:28 AM | #8 |
I was gonna ask if I could shoe horn them in, but feared I’d be mocked... lol. While I’m on LURC site, Anyone know if the “Ultra hubs - cover style” fit these wheels? http://www.lockeduprc.com/Ultra-Hubs...yle_p_904.html The hubs are 10.2mm wide but I don’t have an accurate gauge to measure the opening in my wheels. Either way folks, tremendous help! Thank you... Sent from my iPhone using Tapatalk |
02-11-2020, 11:37 AM | #9 |
Those "locking" hubs won't fit on your sawback axles (at least I'm assuming that's what you're trying to use them on, based on your other recent posts), there's just not enough thread sticking out on your stub shafts. However, these: Ultra Hubs - Front M4 should work.
02-11-2020, 12:23 PM | #10 | |
| Re: Scale hardware for “Chanquish” wheels & VP style hubs? Quote:
I haven’t gotten that far yet with the Sawback build, but good looks! Thank you. These 2 sets of wheels are actually going on my BOM and Gelande2 JK. So the G2 will require the ones you pointed out, which may be too wide for the “Chanquish” wheels... Sent from my iPhone using Tapatalk | |
02-11-2020, 08:20 PM | #11 |
I read "suggested for snowman" on the hub compatibility list and was stuck for a sec, trying to think of what the heck rig that could be before it hit me... YETI! |
02-12-2020, 04:42 AM | #12 |
| Re: Scale hardware for “Chanquish” wheels & VP style hubs? |
03-14-2020, 04:22 PM | #13 |
Quarry Creeper Join Date: Jun 2004 Location: Melbourne Australia
What size are the scale bolts in the beadlock ring mate?
03-16-2020, 10:45 AM | #14 |
Newbie Join Date: Nov 2019 Location: Rockwall
what is the hardware listed under on locked up site?
03-17-2020, 04:58 PM | #16 |
Rock Crawler Join Date: Mar 2013 Location: Waukesha
03-18-2020, 11:06 AM | #17 |
| Scale hardware for “Chanquish” wheels & VP style hubs? I used SSD M2x5 scale bolts. NOTE: The SSD tool (bit) for the bolts is literally a hair too thick to fit the opening of the "Chanquish" rings. I had to file the sides of the bit down some. This probably isn't the same for REAL Vanquish or other similar rings... just my experience with the ebay ones. ALSO: I used an M3 button head to start the tiny m2x5 bolts in. They fit in the head perfectly and make the process rather pleasant. JUST DONT FORGET which ones need to be properly "torqued" down as the button head doesn't allow you to! [see below] |
03-18-2020, 11:19 AM | #18 | |
ALSO confirming that the above mentioned Acorn nuts work on these wheels and DO thread into the “Chanquish” metric VP/SLW style hubs (this part isn’t as pleasant/therapeutic though... lol) it takes a tiny bit of tighten/loosen but minimal resistance still. And the eBay replacement hubs are like $6-10 if you really mangle them somehow :-D Sent from my iPhone using Tapatalk | |
03-18-2020, 01:05 PM | #19 | |
Nope now I remember I had to turn down my tool a bit to fit in the vanquish rings on mine. Maybe just for my specific ring but I did have to do it Sent from my iPhone using Tapatalk | |
03-19-2020, 06:39 AM | #20 | |
I was able to get 2 full sets of wheels in one sitting but the bit finally stripped, so Ive got to use one of the other supplied bits, so any tips? | |
Scale hardware for “Chanquish” wheels & VP style hubs? - Similar Threads | ||||
Scale Aisin/Yota Style Hubs and Scale Rear Hubs V2 | aka_boogo | RC4WD Trail Finder 2 | 5 | 03-15-2015 07:41 PM |
