Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tires and Wheels
Thread: Rim Choice
Old 05-27-2004, 03:22 PM   #1
Default Rim Choice
are their any rims out there that will fit a TXT & the Jumbo Swamp Dawgs other that the IMEX ones without having to use an adapter or switch to clod axles?
ultralord is offline   Reply With Quote
Old 05-27-2004, 04:01 PM   #2
Default Re: Rim Choice
make them fit on the TXT wheel. You can do it.
DirkDigler is offline   Reply With Quote
Old 05-27-2004, 04:20 PM   #3
by cutting the tire? not sure as i have the guts to do that. any other suggestions?
Old 05-27-2004, 04:29 PM   #4
No. The TXT wheel is smaller than the tire hole on the IMEX tire. You would need to increase the tire hole diameter. This is easily done. You can see how I did it with my BFT tires on TXT Wheels. Should work out about the same with the IMEX tires. As for width, that won't be any problem at all.
Old 05-27-2004, 04:29 PM   #5
There is a writeup on the first page about what I think Dirky boy is reffering to...
SR5Dave is offline   Reply With Quote
Old 05-27-2004, 04:35 PM   #6
ahh i see it.. maybe ill give it a shot.
