Not my beloved Rovers! I’ve been running 2.2 white dot Rovers since 2010 or so. Super happy with the tire. I ended up sanding the sidewalls which made them even better, but I finally put a gash in one today. If white dot rovers were still available, I’d simply replace it no questions asked. They’re unavailable everywhere though, which leaves me to searching for a replacement. I like the smooth sidewalls, but I also like the bigger tread blocks. I’m in the Midwest and dirt is common amongst the rocks. Are there any recommendations for a comp tire similar to the Rovers? I’m torn between getting another set of similar tires and sanding them, or rolling the dice on some Voodoo Pins to see how they do on my terrain. |
Re: Not my beloved Rovers! |
Re: Not my beloved Rovers! I'd personally stay with white dot rovers. Rcpcrawlers.com has rovers. Just my 2 cents. http://rcpcrawlers.com/product.php?p...age=1&featured How bad is the rip? I've ripped many of tires and just glued them back together no problem. Sent from my SM-A505U1 using Tapatalk |
Re: Not my beloved Rovers! Quote:
Thanks, |
Re: Not my beloved Rovers! JConceps Ruptures look very similar. They offer them in both 1.9 and 2.2 https://www.jconcepts.net/shop/ruptu...ce-racer-tires |
Re: Not my beloved Rovers! I saw brand new rovers hanging on the wall at my LHS two weeks ago. |
It's pretty bad. Completely removed a chunk of rubber about the size of a nickel. I noticed it because I could see my foam peeking through, haha. Quote:
Re: Not my beloved Rovers! I will put in a second shout for the rovers. They really are a nice tire. For normal rocks and the odd dirt patch they do really well. On those really smoothed out and rounded river stones, they're a bit meh but that really doesn't detract much. Definitely NOT for wooden crawler courses as the sidewalls are rather thin so the odd sharp stick or splintered bit of wood will tear right through them. I know from experience:roll: |
Also pick up a set from rcpcrawlers.com . Sent from my SM-A505U1 using Tapatalk |
I went ahead and ordered a pair of Rovers from rcp. Thanks guys! |
Re: Not my beloved Rovers! I have a set of 4 white dot rovers I’m not even using if interested |
