05-03-2020, 12:12 PM | #1 |
Newbie Join Date: Feb 2020 Location: Hilton Head
| Tire/Foam Help
First off, I did read a similar thread related to a similar issue with 2.2 and dual-stage, and this issue is indeed different. I just bought a set of 1.9 Proline Hyrax tires and dual-stage foams for my Axial SCX10.3. Unfortunately, the foams do not fit. The OD on the tires is approximately 4.15," and the OD on the 1.9 dual-stage foams is 4.85, which is .60 larger in diameter than the stock foams that come with the Hyrax tires. Although I managed to get them on, the tires are clearly overstuffed with the hard foam extending above the sidewall into the tread area. The foam package states, "for Proline 1.9 XL tires," but I can not find any other dual-stage 1.9 foams other than the XL. What am I missing? Does a Proline 1.9 dual-stage foam exist that is not for XL tires? I can not find one. I would appreciate any guidance. |
05-03-2020, 01:27 PM | #2 |
| Re: Tire/Foam Help
I use CI foams, thats what I know... https://crawlerinnovations.com/lil-nova/1-9-4-0/ https://crawlerinnovations.com/lil-nova/1-9-4-25-1/ usually go a bit smaller depending on foams and tire, I don't know of any 4.19 specifically |
05-03-2020, 05:39 PM | #3 |
| Re: Tire/Foam Help
Proline does not make dual stage foams for 4.19 tires, only the XL versions (4.75) The CI foams above will work great. |
05-04-2020, 06:44 AM | #4 |
| Re: Tire/Foam Help |
05-04-2020, 07:32 AM | #5 |
Rock Stacker Join Date: Mar 2020 Location: Boise
| Re: Tire/Foam Help
[IMG][/IMG] Try crazy crawler they have different sizes available debending on od - width. |
05-04-2020, 02:45 PM | #6 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
05-04-2020, 04:12 PM | #7 |
RCC Addict Join Date: Aug 2005 Location: SoCal
| Re: Tire/Foam Help No, they're single stage foams with a star cut pattern in them. To OP, as mentioned, Proline only makes foams for their bigger 4.75 tires not their 4.19 tires. The CI foams are a good option, I would look at the 4.25 comp cut inner foams. I've found the 4.0 foams to be a tad too soft and the 4.25 standard cut inner to be a tad too firm. |
05-04-2020, 05:24 PM | #8 | |
| Re: Tire/Foam Help Quote:
05-07-2020, 10:37 AM | #9 |
Pebble Pounder Join Date: Mar 2020 Location: san diego
05-07-2020, 12:17 PM | #10 |
| Re: Tire/Foam Help You can't use Proline foams in 4.45" tires and expect good results. The Proline foams are designed for 4.7" tall tires.
05-07-2020, 09:36 PM | #11 | |
I imagine they'd work great for what they were designed for... My mistake :( | |
05-17-2020, 10:58 AM | #12 | |
Quarry Creeper Join Date: Dec 2016 Location: Toronto
I imagine if they make foams for 4.2" tires they would refer to them as class 1 or something similar based on their XL nomenclature. Edit - I just realized that you might not be speaking sarcastically - rather literally saying that the foams would be good for what they were meant for - that's on me for misreading, my apologies. Last edited by MrBlank; 05-17-2020 at 11:09 AM. | |
05-29-2020, 10:18 AM | #13 | |
It's all good. My friend actually has a set of Proline TSL 1.9 swampers with stock foam so i sold my proline dual stage foams to him (4.75 OD). It's working well for him. | |
05-29-2020, 11:54 AM | #14 | |
I also remember seeing the proline ones at my LHS (can't remember the price) but I am satisfied with the stock foams in my current setups, and any future tires I buy will likely be 4.2" - 4.5". Sent from my SM-G925W8 using Tapatalk | |
Tire/Foam Help - Similar Threads | ||||
Tire foam? | golokobori7672 | Newbie General | 10 | 01-26-2020 08:46 AM |
Deuce's Wild XL Foam Pair; 3.8" ID; Yeti XL Foam / BFG Krawler Tire | Nova's Ark | Crawler Innovations | 12 | 08-31-2015 08:20 AM |
Tire foam? Why? | HiloDB1 | Hawaii | 6 | 05-22-2008 01:15 AM |
tire foam or not??? | 4tecJeeps | Tires and Wheels | 7 | 03-05-2007 08:50 AM |
