Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Tire/Foam Help
Old 05-03-2020, 12:12 PM   #1
Default Tire/Foam Help
First off, I did read a similar thread related to a similar issue with 2.2 and dual-stage, and this issue is indeed different.
I just bought a set of 1.9 Proline Hyrax tires and dual-stage foams for my Axial SCX10.3. Unfortunately, the foams do not fit. The OD on the tires is approximately 4.15," and the OD on the 1.9 dual-stage foams is 4.85, which is .60 larger in diameter than the stock foams that come with the Hyrax tires. Although I managed to get them on, the tires are clearly overstuffed with the hard foam extending above the sidewall into the tread area. The foam package states, "for Proline 1.9 XL tires," but I can not find any other dual-stage 1.9 foams other than the XL. What am I missing? Does a Proline 1.9 dual-stage foam exist that is not for XL tires? I can not find one.
I would appreciate any guidance.
Richr8 is offline   Reply With Quote
Old 05-03-2020, 01:27 PM   #2
Default Re: Tire/Foam Help
I use CI foams, thats what I know...
https://crawlerinnovations.com/lil-nova/1-9-4-0/
https://crawlerinnovations.com/lil-nova/1-9-4-25-1/
usually go a bit smaller depending on foams and tire, I don't know of any 4.19 specifically
mikemcE is offline   Reply With Quote
Old 05-03-2020, 05:39 PM   #3
Proline does not make dual stage foams for 4.19 tires, only the XL versions (4.75)
The CI foams above will work great.
OSRC is online now   Reply With Quote
Old 05-04-2020, 06:44 AM   #4
Unbelievable, but thanks. I will look into the CI's.
Old 05-04-2020, 07:32 AM   #5
[IMG][/IMG]
Try crazy crawler they have different sizes available debending on od - width.
Callelk is offline   Reply With Quote
Old 05-04-2020, 02:45 PM   #6
Those aren't dual stage though. Are they?
QuesoDelDiablo is offline   Reply With Quote
Old 05-04-2020, 04:12 PM   #7
No, they're single stage foams with a star cut pattern in them.
To OP, as mentioned, Proline only makes foams for their bigger 4.75 tires not their 4.19 tires.
The CI foams are a good option, I would look at the 4.25 comp cut inner foams. I've found the 4.0 foams to be a tad too soft and the 4.25 standard cut inner to be a tad too firm.
VMGontheRocks is offline   Reply With Quote
Old 05-04-2020, 05:24 PM   #8
Ordered. Thanks! Now what do I do with these proline 1.9 XLs? :(
Old 05-07-2020, 10:37 AM   #9
Same issue for me...
Pitbull rock beast 4.45 OD and prolines 4.75 ad they feel really.. reallly stiff..
Maybe keep the foam in case you get a bigger tire down the line? or... you can always sell :(
food2000 is offline   Reply With Quote
Old 05-07-2020, 12:17 PM   #10
Moderator
JatoTheRipper's Avatar
You can't use Proline foams in 4.45" tires and expect good results. The Proline foams are designed for 4.7" tall tires.
Old 05-07-2020, 09:36 PM   #11
Yeah, i had no idea the OD matters when selecting a foam... i just read PL 2 stage foams are good! so i clicked and bought.
I imagine they'd work great for what they were designed for... My mistake :(
Old 05-17-2020, 10:58 AM   #12
That's a little silly, they do work great for what they were designed for - their full size / XL 1.9 tires.
I imagine if they make foams for 4.2" tires they would refer to them as class 1 or something similar based on their XL nomenclature.
Edit - I just realized that you might not be speaking sarcastically - rather literally saying that the foams would be good for what they were meant for - that's on me for misreading, my apologies.
MrBlank is offline   Reply With Quote
Old 05-29-2020, 10:18 AM   #13
It's all good.
My friend actually has a set of Proline TSL 1.9 swampers with stock foam so i sold my proline dual stage foams to him (4.75 OD). It's working well for him.
Old 05-29-2020, 11:54 AM   #14
It's all good.
Good to hear! I have yet to try aftermarket foams, mostly because with the exchange rate, lack of local availability for C.I. foams, shipping, etc. - that they would cost somewhere in the neighbourhood of $40-$50 for a set and since I am not involved in any competitions they don't seem necessary.
I also remember seeing the proline ones at my LHS (can't remember the price) but I am satisfied with the stock foams in my current setups, and any future tires I buy will likely be 4.2" - 4.5".
Sent from my SM-G925W8 using Tapatalk
Tire/Foam Help - Similar Threads
Tire foam? golokobori7672 Newbie General 10 01-26-2020 08:46 AM
Deuce's Wild XL Foam Pair; 3.8" ID; Yeti XL Foam / BFG Krawler Tire Nova's Ark Crawler Innovations 12 08-31-2015 08:20 AM
Tire foam? Why? HiloDB1 Hawaii 6 05-22-2008 01:15 AM
tire foam or not??? 4tecJeeps Tires and Wheels 7 03-05-2007 08:50 AM
