09-03-2020, 08:23 AM | #1 |
Rock Crawler Join Date: Apr 2020 Location: Drums
| CI foams way bigger than the tires
After successfully removing my Canyon Trails from the glued stock rims, I now want to mount them on a set up steelies. Wanted to try a set of CI dual stage foams. I ordered the 4.5" and they just came in. The 4.5" foams are substantially larger than the 4.7" tires (actually measure 5 1/4" out of the package). I'm assuming I just shove them in there. My last two sets of Proline dual stage were a little larger than the tires but not as much as these. Also, just noticed the CIs appear to have tree layers. The outer layer is a "tuning" layer. I assume I can take that off and just leave the other two if needed for fitment (shovement )? Or is the tuning layer for foam performance, not tweaking the fit? Thx......... |
09-03-2020, 08:29 AM | #2 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
| Re: CI foams way bigger than the tires
It is so they properly fill out and support the tire. Run without the tuning layer first just to see how you like it.
09-03-2020, 09:07 AM | #3 |
| Re: CI foams way bigger than the tires |
09-28-2020, 08:41 PM | #4 |
Newbie Join Date: Nov 2011 Location: kansas
Did you get the foams figured out?
09-28-2020, 09:12 PM | #5 |
I believe they recommend undersizing the foams 1/4" compared to the tires OD. You can undersize the foams further to soften them and get them to conform to the terrain even more. |
09-29-2020, 06:34 AM | #6 |
Quarry Creeper Join Date: Aug 2020 Location: Springfield
I thought the same thing, didn't include the tuning rings just do to the size. And regret not adding them. |
CI foams way bigger than the tires - Similar Threads | ||||
Stretch or trim foams for bigger wheel? | Brake Weight | Tires and Wheels | 5 | 11-06-2019 07:46 AM |
Bigger Tires on WK | RockRider | HPI Wheely King | 20 | 06-15-2008 06:46 AM |
I Need Bigger tires!! | MuddinJeepXJ | XTM Crawler | 15 | 02-08-2008 07:40 AM |
bigger tires | greenmachine | General Crawlers | 11 | 06-08-2006 04:45 PM |
bigger tires? | JaKeLeE | General Crawlers | 4 | 06-06-2006 09:39 PM |
