Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Tyre compress
Old 09-13-2020, 11:28 AM   #1
Default Tyre compress
Hi all.
Several years ago i came across a tyre compress template for download and print out. it involved buying threaded rod, nuts, washers and star thumb screws, and clear acrylic sheets. Basically you put your tyre between two dohnut shaped rings and tighten down the screws with the hand nuts, this allows easy mounting of your beadlocks. Does anyone know where this template and material details is located. If i cant find it i have a good idea how to build it but the details will help. Thx
bezzy300472 is offline   Reply With Quote
Old 10-02-2020, 06:16 PM   #2
Default Re: Tyre compress
Not what you're asking but I've been using zip ties and cinching the rims together. Works quite well.
Tangmere is offline   Reply With Quote
Tyre compress - Similar Threads
Changing stock shock oil, help! Won't compress big_poppa49 Axial SCX-10 5 02-19-2017 10:31 AM
how to compress pics even more so ??$? Udigoo Chit Chat 5 07-17-2010 07:23 PM
What tyre could be used besides the stock tyre? lotaloi Losi Micro-Rock Crawler 2 03-31-2010 06:22 PM
What 1.9 Tyre to get? Kanzai Tires and Wheels 2 12-01-2007 01:39 PM
How can i make the tyres compress? 4x4crawler General Crawlers 10 10-08-2006 09:20 PM
