10-02-2020, 10:23 AM | #1 |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
| Bomber 2.0 Wheel Question
Are these wheels any good? Thought about picking up a set for my son's Wraith as they are on sale right now and come with a wider hex hub. His stock axial beadlocks aren't working as the tires hit the shock Springs when he turns left or right. https://www.amainhobbies.com/axial-r...20AMainHobbies Sent from my LM-G710VM using Tapatalk |
10-18-2020, 06:18 PM | #2 |
Quarry Creeper Join Date: Jan 2016 Location: Southampton
| Re: Bomber 2.0 Wheel Question
Not sure about the quality but they look nice. With the different length adapters you should be able to set them up so they don't rub. Just be careful if you are mounting Proline tires on them. Prolines tend to have a thicker bead on their tires and they can be cut by some rims. If the aluminum is sharp it makes it worse. Hope this helps. Good luck
10-18-2020, 07:14 PM | #3 |
Quarry Creeper Join Date: Aug 2020 Location: Springfield
I just bought these for my u4 rig They are very light and very easy to assemble, even though they are plastic. Beware that they have a pretty significant positive offset. I'd almost prefer if I could run them backwards. You will need a VERY thin wall socket for your axle nut, some T wrenches also won't fit. Scroll to post ~100 or so NK's V1 Bomber Build Last edited by NKlamerus; 10-18-2020 at 07:17 PM. |
Bomber 2.0 Wheel Question - Similar Threads | ||||
Wheel nuts 2.2 Bomber | Jboucher | Tires and Wheels | 15 | 01-10-2019 06:58 PM |
Integy wheel stock bomber tires slip | Voodoobrew | Tires and Wheels | 13 | 09-08-2018 01:08 PM |
Wheel Ideas for Bomber | LSXGMC | Axial RR10 Bomber | 22 | 01-02-2017 10:57 AM |
HPI stock wheel/2.2 wheel beed--Question??? | tecnica2001 | Tires and Wheels | 6 | 10-26-2006 07:49 AM |
