12-09-2020, 04:48 PM | #1 |
Newbie Join Date: Aug 2020 Location: San Diego
| High offset, high clearance 2.2 wheels?
I’m looking for a high offset, high internal clearance (for portals and big knuckle weights) scale beadlock 2.2 wheel. Any tips? I really like my Team Garage Hack 1.9 wheels, and it’d be great if there was a 2.2 wheel out there that’s designed in the same fashion. Metal, 3D printed, etc. - I’m interested in it all. |
12-10-2020, 12:19 AM | #2 |
| Re: High offset, high clearance 2.2 wheels?
How about skipping the "scale" aspect and consider these?: https://dluxfab.com/DLUX-2-2-wheels-p8433871 |
12-10-2020, 06:46 AM | #3 |
RCC Addict Join Date: Aug 2020 Location: Jacksonville
Noob question alert...what keeps the foams from getting wet with those (or the tires from filling up with dirt/debris). Seems like there's a part missing haha.
12-10-2020, 07:12 AM | #4 |
High offset 2.2s - https://motoworxracing.com/?product=...-space-wheel-2 |
12-10-2020, 12:00 PM | #5 |
| Re: High offset, high clearance 2.2 wheels? Nothing. You could put a strip of lexan in there if yoo wanted to help the foam keep its shape better and keep bigger debris out, but it will find it's way in. Probably not a great option for the scale & trail type, but a functional option for lightweight comp crawlers. He also makes a similar wheel that allows for "loaded dice" knuckle weights which are place the tungsten/brass weights down inside of the tire while still maintaining a 2.2" bead surface. If "big knuckle weights" were the goal, that's a solid solution.
12-10-2020, 05:02 PM | #6 | |
| Re: High offset, high clearance 2.2 wheels? Quote:
Those are awesome. Thanks! | |
High offset, high clearance 2.2 wheels? - Similar Threads | ||||
High Offset 1.55 wheels | dankycrawler | Tires and Wheels | 6 | 04-01-2020 04:55 PM |
High Clearance Links | jtessmer88 | Axial SCX-10 | 6 | 02-18-2015 06:33 AM |
AX10 high clearance knuckles with 1.9 wheels? | low82 | Newbie General | 4 | 07-02-2010 03:25 PM |
high offset wheels | dblmotes | Tamiya TLT Crawlers | 6 | 02-15-2006 04:23 PM |
