07-10-2021, 06:35 PM | #1 |
Newbie Join Date: Jul 2021 Location: Bellevue
| Best foams for a lot of creek driving?
Looking to get other than stock tires on my trx4 bronco.. going either PL super swamper xl, or duratrax deep woods..I do a lot of water driving.... I have some PL dual stage, but thinking maybe ottsix halo? |
07-10-2021, 06:44 PM | #2 |
| Re: Best foams for a lot of creek driving?
CI dual stage ….. here’s a starting spot. https://crawlerinnovations.com/deuce...l-foam-pair-2/ Hang up and Drive |
07-10-2021, 07:30 PM | #3 |
There is no good foam for water. ALL foam will require maintenance to dry them out from time to time or they'll break down and rot Best answer is maintenance on whatever foam works best on your rig |
07-10-2021, 08:42 PM | #4 |
you dont need foams pick up a set of smaller tires and run them in side the main tire it acts like a inner tube and not affected by water at all and they dont get flat spots you want about a 1/2" to 3/4" smaller for that perfict aired down tire
07-10-2021, 10:57 PM | #5 |
Quarry Creeper Join Date: Jan 2021 Location: in the Canyon
This is where hair buns + vented tires really shine. I have a set of Canyon Trails with XL hair buns and they work a treat in the water. Any open-cell foam, left wet over time, will break down to nothing. |
07-11-2021, 01:03 AM | #6 |
Quarry Creeper Join Date: Jan 2009 Location: LOADING......
Team ottsix halos are awesome, and supposedly waterproof.
07-11-2021, 05:16 AM | #7 |
Rock Crawler Join Date: Mar 2019 Location: Terrassa
A.L.T. foams are wicked too.
07-11-2021, 07:06 AM | #8 |
in my opinion the problem with foams is you pay a bunch of money and if you forget and leave the rig sitting on its wheels your new over priced foams are trash unless your realy in to canadian style tires my foams always.turned to doughnuts enuff flat spots and your round again but the foams are now half the size on the outside and twice the size on the inside leaving a floating foam doughnut inside the tire the inner tire suport system is easy and predictable once tuned to the tire the wheels can be used on any rig with out changes they will perform the same on day 1 as they do on day 1000 no matter how hard you are on them or what you run them through the only real downside is the waight but on a scaler thats a good thing |
07-11-2021, 08:05 AM | #9 | |
| Re: Best foams for a lot of creek driving? Quote:
Foam break in is a good thing and anyone that knows what they're doing buys the appropriate foam setup knowing how they will be once broken in. It isn't just about the aired down look, foam controls all movement of the tire whether it be forward, sidehill or controlling wrinkle under traction it does it all. Basically running them as balloons provides none of that action. If it works for you then more power to you but a lot of us are 100% performance oriented and have a decent grasp on what we're doing. | |
07-11-2021, 03:28 PM | #10 | |
it works just like the fill sized version but they call them internal beadlocks on full sized rigs the inner tire dosent fill the tire like a standered foam or a dual stage foam dose there is a gap more like single stage foams but more tuneable and as a bonus my tires dont go canadian if they sit on there wheels for a year between runs and can be reused over and over again when the outer tire wares out the only performance advantage foams have is they weigh less and thats not realy a advantage on a scaler | |
07-12-2021, 10:55 AM | #11 | |
No, just no. Like I said, you do you and the rest of us will do what's good. Light weight wheels and tires are definitely an advantage in every class of crawler. Light weight doesn't break parts and it accelerate and stops faster which is always advantageous in a comp scenario. Yea I know you probably don't comp so you don't care, whatever you wanna do is fine but don't tell the world full of impressionable noobs that you're right and the entire industry is wrong because some idiots will actually believe it | |
07-12-2021, 11:42 AM | #12 | |
RCC Addict Join Date: Jun 2008 Location: Mudville
Don't recall voting to give up my voice to "THE REST OF US" at any point in my life. If you're doing a lot of Water running. Don't vent or use any foams. Seal the tires to the rims with seme rtv silicone. BUT, before you tighten the last Beadlock down, push a bit of the air out of the wheel. I use a zip strip around the center of the wheel pulling it snug, which pushes a bit of the air out of the loose Beadlock ring and holds it there. Then when it's about where you want it, tighten the deadlock rings. I use a little rtv silicone around the bead on the rim/tire seat so it fully seals to the tire. let them set for a day for the rtv to cure. It stays pliable and keeps the water out of the wheels until you take the rings off and pop the seal. the rtv will pull off pretty easily not messing up the tires or the beadlocks or rims. Basically, you are making kind of a negative pressure in the tire when its sealed and you remove the zipstrip etc, the tire wants to go back to full round, and the lesser volume of air allows the tires to mold around the rocks, but not compress right to the rim so it isn't Firm but not flat either. It can be a bit of a pain, but once you got the first one, use that zip on the other tires and it will make them pretty equally set. I know every other "The Rest of Us" will scoff at this and only do what everyone else told them to do on some forum or some rc club. But in the real world, you use what works for what you're doing. Sure Right TOOL for the Right Job. Pro Tip. There are more tools than 'The Rest Of US' may be aware of. LMMFAO... For a lot of water running, it works great. Just got to get the right Pressure" in the wheels, no need to add any air buttons as for crawling etc, you want them some what softer anyways. Last edited by Timmahh; 07-12-2021 at 11:54 AM. | |
07-12-2021, 11:44 AM | #13 | |
Still works today. Another good unknown tool for 'The Rest Of Us" to learn about. lol Last edited by Timmahh; 07-12-2021 at 11:55 AM. | |
07-12-2021, 03:43 PM | #14 |
Lemme see, double tires, silicone the rims foams get flat, and hold water. Thanks WT, at least I’m not the only one. I listened to Eddie and I haven’t replaced any foams yet. But I’m only in the Everglades, so I’m gonna need tracks? All my trucks tires never touch ground unless running, stands are cheap Hang up and Drive |
07-12-2021, 08:23 PM | #15 | ||
and most of my rigs are big and heavy not even the new heavy foams from ci can handle that pig and even those just came out so what was i saposed to do for a rig like that there wasent anything anywere for rigs over 15lbs i so did something else i learned to make them work Quote:
most of my rigs live stacked in the corner of the hobbie house the ones i use alot and im working on live on the bed of the rv the smaller ones live under the bed in the main house i even started puting them in the attic till the tire started drying out and falling apart the wife dosent like them in the main house even though theres always a few left out Last edited by ferp420; 07-12-2021 at 08:44 PM. | ||
07-12-2021, 09:35 PM | #16 | |
You and your 87 pound rigs are not the rule, you are the extreme minority. So like I said, you do you but you should definitely qualify your recommendations so there isn't a string of noobs trying stuff that won't work on their 6lb scx10.2. | |
07-12-2021, 10:27 PM | #17 | |
when i was a kid bicycle tires were filled with foam but people found out there are better options motorcyclez were the same way they used foam in the tire they since moved on to all balls tire system i have a feeling rc tire will go down the same road foams are old news kinda like um ya Last edited by ferp420; 07-12-2021 at 10:30 PM. | |
07-12-2021, 11:11 PM | #18 | |
Foam is old tech at its base but it is still progressing and being refined every day. | |
07-13-2021, 07:04 AM | #19 | |
foams are not progressing and there not even making foams for all size tires there on there way out theres no reason this set up would bounce thats just ignorance the tires are not sealed there is no bounce ive sead this isent for comp rigs its to heavy for a comp rig were your watching the weight of every part but on a scale rig they work realy good and if your breaking part from the extra weight then your using the wrong parts i understand its not your thjng but just cause you cant figure it out dosent mean someone else cant and you dont get to speak for everyone so go stuff your tire with foam and enjoy it Last edited by ferp420; 07-13-2021 at 07:09 AM. | |
07-13-2021, 07:50 AM | #20 | |
