07-20-2021, 10:49 AM | #1 |
Newbie Join Date: Jul 2021 Location: Bellevue
| Proline closed cell foam
Any input? 8.5 pound trx4 bronco, will probably do super swampers, I drive in creeks alot..
07-21-2021, 08:40 AM | #2 |
| Re: Proline closed cell foam
they will work just fine you might want to vent your tires to keep the rotating weight down even closed cell foams have holes that fill with water they wont hold it but the tires will so venting the tires gets the water out the fastest and easyest
07-30-2021, 03:04 AM | #3 |
Newbie Join Date: Jul 2021 Location: Ardellaborough
In case you weren't aware, there is no air pressure because i punch out 3 very small holes between treads on each tire to let out water and also to keep a consistant footprint without any bouncing around. Psi (of foam) should be the same as stock its just only affecting less than half the volume of the tire MyBPCreditcard login Last edited by Karolann; 07-31-2021 at 02:10 AM. |
Proline closed cell foam - Similar Threads | ||||
Proline CLosed cell or CI Closed cell.....which is softer? | wyd | Tires and Wheels | 6 | 12-26-2018 08:02 PM |
Closed cell foam in rear only? | maverick67 | Tires and Wheels | 6 | 07-07-2017 09:11 PM |
Trimming CI closed cell foam | Odd-M | Tires and Wheels | 5 | 04-10-2015 12:31 AM |
Cheap closed cell foam tire mod. | Werty Made | Tires and Wheels | 15 | 01-11-2013 08:10 PM |
