Foam recommendations for one heavy trail rig. Hi Guys, I'm looking for some help with foam options for my Gelande2 defender 110. She's got a roof rack and other bits thatve increased the weight and made the tires look flat. Most 2 stage or better foams I see are for wider/taller tires. Is there anything out there for the Narrow 1.9 Dirt Grabbers by RC4WD? Thanks, Daniel https://live.staticflickr.com/65535/...4d1ca5b2_o.jpgD110c by Daniel Dalton, on Flickr |
Re: Foam recommendations for one heavy trail rig. CI single stage foam? They are great on my trx4. |
Re: Foam recommendations for one heavy trail rig. Check out the Crazy Crawler foams . |
Re: Foam recommendations for one heavy trail rig. 1 Attachment(s) I'm thinking these could work... https://crawlerinnovations.com/lil-n...er-firm-outer/ You might have to shave down (narrow) the closed cell inner foam slightly, but the firm outer should make up for the small 3.375" diameter of the inner foam. It says they're designed for 6lb max trucks, but I use those li'l novas in the 4.5" size with soft outers in 4.76" tires on a 9+lb truck with no issues. |
