10-16-2021, 03:09 PM | #1 |
Newbie Join Date: Jul 2017 Location: Kentucky
| Softer tires?
I’m reading WD40 softens tires, has anyone tried it? I have an older set on my Wraith that could used some help, seems to have gotten harder with age. I would have thought it would make them to slick
10-16-2021, 03:14 PM | #2 |
| Re: Softer tires?
I would start by cleaning them with simple green. The no prep drag guys do this, and it’s a different tire. Bigger issue will be those foams, they dry out and turn to dust Hang up and Drive |
09-28-2022, 11:43 PM | #3 |
Newbie Join Date: Sep 2022 Location: USA
| Re: Softer tires?
Pollution values output is a method of quantifying the negative environmental impact of economic activity. It linkedin profile writing service share assigns a monetary value to releasing pollutants into the environment and aggregates these values to measure the overall cost of environmental degradation.
09-30-2022, 07:23 AM | #4 |
Rock Crawler Join Date: Feb 2020 Location: Fort Leonard Wood
| Re: Softer tires? Usually an petroleum product will make rubber break down faster or a tire break IN faster.
09-30-2022, 05:20 PM | #5 |
| Re: Softer tires? |
10-10-2022, 03:35 AM | #6 |
Newbie Join Date: Oct 2022 Location: Hustan
| Re: Softer tires?
Quite simply, softer rubber grips a dry surface, while hard rubber tends to slide over it. That grip is essential for acceleration and cornering as well braking, softer tires do a better job of getting you going and keeping you safe https://www.collegebasics.com/blog/best-research-paper-writing-service/ |
Softer tires? - Similar Threads | ||||
Softer tires for crawling | waqr | Axial Wraith | 24 | 01-09-2017 11:15 PM |
softer tires | hairba11 | Tires and Wheels | 5 | 03-23-2007 12:57 PM |
softer tires | SlammedMini469 | General Crawlers | 4 | 01-12-2006 09:39 PM |
softer tires? | hackster | Tires and Wheels | 8 | 06-01-2004 06:40 PM |
Softer tires! would this work? | rcracer | Tires and Wheels | 3 | 05-12-2004 08:08 PM |
