![]() | #21 | |
Quarry Creeper Join Date: Jun 2013 Location: Portugal
| ![]() Quote:
Countries with good wages can't do cheap parts or they will lose money | |
![]() | #22 |
Quarry Creeper Join Date: Jan 2020 Location: MIAMI
I am about half and half between cheap Amazon wheels and name brand ones. Among my favorite branded wheels are the steelies from SSD. Four can be had for $55 which is pretty competitive with the no name Chinese units. https://www.amainhobbies.com/ssd-rc-...d00272/p792687 I’ve never had a problem mounting any tires to them and being made of steel they add a good amount of weight where you want it ![]() |
![]() | #23 |
Pebble Pounder Join Date: Feb 2022 Location: Batam Island, Indonesia
Just bought 68 euro heavy crawler wheels 868 gr per 4 rims from AliExpress, can't go wrong with that, also 4 new super swamper tires , all 2.2 size It will be my first time assembling RC wheels & tires, i will try to make them airfilled ( @ferb420 gave me a idea ) i bought some rubber plugs to seal them, if it doesn't work i bought 2 sets of different foam also, hi hi ![]() ![]() Sent from my CPH1937 using Tapatalk Last edited by BP6666VR; 10-01-2022 at 08:22 PM. |
![]() | #24 |
sketchiness abounds... ![]() Join Date: Jun 2016 Location: Austin
Gotta say the Element bronze plastic Method 701 Trail Series wheels and their black The Ochos work really well if you swap the plastic hex hub for either aluminum or brass, both available direct. They don't have that overly thick outer rim that Axial plastic beadlocks have, making them look more scale in my opinion. I've got LockedUpRC, Vanquish, Incision, SSD, GearHead, RC4WD, Boom Racing, Injora, and some complete unknown manufacturer for aluminum/steel wheels. Last edited by durok; 10-01-2022 at 10:54 PM. |
![]() | #25 | |
Rock Stacker Join Date: Sep 2022 Location: Central CT
| ![]() Quote:
![]() | #26 |
they allready did all that too
![]() | #27 |
RCC Addict ![]() Join Date: Mar 2019 Location: Hemet
One thing not mentioned is the inconsistency.. I’d you buy vp wheels, you know that the tanks, 105’s and I forget what others are going to be 1.0” wide and all the others .8” wide. Same with other companies. Chanquish and other knock off wheels in similar styles are drastically inconsistent with width. I ordered a set of knock off 2.2’s that were listed at 1.0” and they showed up being ~0.7” which I was fine with because I like slimmer wheels but I’m just saying. I’m fortunate enough to own some really nice rigs, and most of my rigs are on name brand wheels.. mostly bought second hand for far less than retail.. Sent from my iPhone using Tapatalk |
![]() | #28 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
I ran mostly ebay VP knockoffs for years and never had an issue with them. VP are machined and finished better, but cost 3-4x as much by the time you buy hubs and hardware, and for some reason they still use SAE hardware, which annoys me. Their hardware is not better in my experience. I still usually break at least one screw in one ring even using a very light clutch setting on my M12 driver. The only wheels that I truly had a problem with were a batch of the first Incision wheels. The hex fit was so sloppy my axle nuts would constantly back off even if using brand new serrated nuts.
![]() | #29 |
i just.found this set of cheap chinese wheels 2.2s for $25 +3 day shipping https://www.ebay.com/itm/16520280515...mis&media=COPY i already have more than i need right now so i thought i would share there seems to be alot at this price right now ive found 4 or 5 other listings for the same price Last edited by ferp420; 10-10-2022 at 07:44 AM. |
![]() | #30 | |
RCC Addict Join Date: Jun 2008 Location: Mudville
| ![]() Quote:
Maybe why so cheap. JS. | |
![]() | #31 |
![]() | #32 |
Rock Stacker Join Date: Nov 2022 Location: Norway
I got these today: https://www.ebay.com/itm/284476591212 Well, I had them for about a week, but I got new beadlocks for them, so I got to test them out. ![]() ![]() Bought them with the dual stage foam. I have to say I really REALLY like them. I've only tested them versus cut stock wheels though, super grippy, carves it's way through snow. They seem somewhat thin, and I suspect by the feel (I know right?) that they won't do well with uv exposure. Last edited by SleptOver; 11-10-2022 at 11:19 AM. |
![]() | #33 |
Btw, https://www.ebay.com/itm/384773418080 are the wheels I have, I am super happy with them. They appear to be of really high quality. Fairly hefty too.
![]() | #34 |
Quarry Creeper Join Date: Feb 2009 Location: IN MY HOUSE
have many truck wheels with no problems.. some smaller road wheels have been in funny sizes.
![]() | #35 |
Quarry Creeper Join Date: Jan 2009 Location: WA state
Does anyone know if the beadlock rings they sell on amazon will fit SSD wheels? or any brand of rings that will fit SSD wheels?
![]() | #36 | |
| ![]() Quote:
I imagine if you find a beadlock ring with the same number of bolts, they should likely fit so long as Diameter is also close to the same. | |
![]() | #37 | |
| ![]() Quote:
Now that I think about it I think jec racing makes rings for SSD...I'll go check there. | |
![]() | #38 |
Quarry Creeper Join Date: Nov 2018 Location: 🌎
All but one of the China wheels I have tried are junk and were not able to be mounted to tires. The one exception is the Austar or now Injora ones like these. Nice thing about these is they are significantly heavier then standard aluminum wheels. ![]() |
![]() | #39 | |
| ![]() Quote:
So I would assume based on this you have your products made over seas, China perhaps? This is not an attack by the way, just asking? | |
![]() | #40 |
I've just recently started to get aluminum beadlock wheels, mainly 2.2 solar. I've bought most <35 shipped and 35mm wide. I also bought a 45mm wide set for 42. These are all aliexpress bought. The one set I have sofar is of good quality and fit. I have many 1/6 scale rigs that only look scale with 2.2, or 2.6 wheels, so cheap is good when outfitting 10+ trucks.
are cheap chinese tire getting better | ferp420 | Tires and Wheels | 6 | 06-08-2019 07:39 PM |
Cheap Chinese ESCs | Alteredgasser57 | Electronics | 24 | 03-25-2019 06:06 AM |
Cheap Chinese beadlock problems | lasllcap@gmail.com | Tires and Wheels | 9 | 07-15-2018 09:36 PM |
cheap chinese 6x6 | CM9000 | Chit Chat | 9 | 06-06-2016 06:28 PM |
