Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Cheap Chinese Wheels
Old 01-24-2023, 10:10 PM   #61
Default Re: Cheap Chinese Wheels
I spent $42 shipped for a set of 35mm wheels and the knock off pit bulls and those tires are on another level of soft that I've ever felt. Near silicone like.
https://a.aliexpress.com/_mtaI1ie
Gula is offline   Reply With Quote
Old 01-25-2023, 06:35 AM   #62
let us know how those tires work out
ferp420 is online now   Reply With Quote
Old 01-25-2023, 09:29 AM   #63
I think options are good. I have Vanquish 1.9, "Chanquish" 1.9, SSD 2.2, 2.2 Punks 3D Carbon Fiber, 1.9 Inverse Carbon Fiber, RC4WD, 1.9 Treal, 1.0 Treal, no name amazon, and others.
Most have been very easy to put together and I haven't had issues with screws stripping on any of these at this time.
jamesbernatchez is offline   Reply With Quote
Old 01-25-2023, 09:35 AM   #64
Know the tires are going to suck. I have a set of the same knock offs in 1.9 and they were crap. Two tires sidewall ripped first time out too. Fine for a cheap trail rig IMO, but actual rock crawling no.
My LCG Cheater build with these tires had to throttle up everything if it even could make it. Swapped over to my friends JConcepts Ruptures and slow crawled up the lines I was previously only able to full throttle up with the bootlegs.
My consensus is cheaper wheels probably OK, but for actual rock crawling and grip, I want the real tires in quality compounds.
Old 01-28-2023, 04:55 PM   #65
I've stumbled upon 2.2 Method Roost knockoffs on Amazon and bought them. I've always liked the Roost from Vanquish but unfortunately can't afford them. I can't also afford a Ferrari so it is fine. The knockoffs are well finished but the beadlock system is not solid like on the VPs...They rely on a inner ring held by M2 screws. The central ring is pretty much useless to. Had to 3D print a narrower ring because the stock one only has about 1mm clearance when the inner ring is tightened
cooper_xl is offline   Reply With Quote
Old 01-30-2023, 02:10 AM   #66
Originally Posted by BP6666VR View Post
I like them ...
Sent from my CPH1937 using Tapatalk
Gentleman, i made a video of fitting these heavy rims and plugged the airholes in the rims so they do not fill up with water & sand .... Cheap Chinese rims, tires & stainless steel bolts
Hahahaha
Smile
https://youtu.be/mOpgShWhdPo
BP6666VR is offline   Reply With Quote
Old 03-11-2023, 06:12 AM   #67
ussprinceton2004 is offline   Reply With Quote
Old 03-16-2023, 08:25 AM   #68
Ive ran a few different sets of cheap wheels along with both boom racing & locked up rc wheels. The boom racing & locked up rc wheels are both way nicer than the cheap ones. They all do the job they are supposed to do though. The only wheels Ive actually had that I cant stand and had constant problems with was RC4WD wheels.
RecklessTrent91 is offline   Reply With Quote
Cheap Chinese Wheels - Similar Threads
are cheap chinese tire getting better ferp420 Tires and Wheels 6 06-08-2019 07:39 PM
Cheap Chinese ESCs Alteredgasser57 Electronics 24 03-25-2019 06:06 AM
Cheap Chinese beadlock problems lasllcap@gmail.com Tires and Wheels 9 07-15-2018 09:36 PM
cheap chinese 6x6 CM9000 Chit Chat 9 06-06-2016 06:28 PM
