03-01-2023, 07:37 PM | #1 |
Pebble Pounder Join Date: Jan 2020 Location: Northern Utah
| Quality tire on chinese beadlock wheels
I have a good (to me) set of Chinese beadlock wheels and am looking for a "good" set of tires to put on them. Now it's mostly rock and some sandy conditions in N. Utah and I don't compete. I have been reading Hyroks may be a problem because of the beads themselves. The wheels I have are metal 1.9. As in this economy money is always a consideration so with these constraints - So what do you guys recommend? BTW I have always run just stock TRX4 Sport tires.
03-01-2023, 08:02 PM | #2 |
Quarry Creeper Join Date: Jan 2021 Location: in the Canyon
| Re: Quality tire on chinese beadlock wheels
If you cut n' sipe those Canyon Trails, throw away the stock foams and replace them with anything better (my favorite being "double buns," the inner from an Amazon dual-stage with a medium hair bun in place of the open-cell foam) you can get properly good performance out of Canyon Trails. I have a number of videos about it on my channel: Canyon Trail Performance Enhancement Dual Stage Hair Buns |
03-01-2023, 08:41 PM | #3 |
yup I had cut my Canyon trails and they really livened up, mine were loose- that un gluing stuff - i've never had good luck with that
03-01-2023, 09:42 PM | #4 |
I saw some tires from an AXIAL early bronco- are they any good? https://jennysrc.com/collections/axi...43013-axi03014 |
03-01-2023, 10:15 PM | #5 |
Rock Crawler Join Date: May 2021 Location: NorCal
These 3 Chinese wheels all have Pro-Line tires. The ones with the silver rings, the beads went in just fine other than the initial few screws it takes to get it started. The last set is actually a 2.0 size, and makes aftermarket foams fit nice and snuggly. 1.9 Boom Racing TE37 reps on 4.19 BFG KM3 with stock foams 1.9 Vanquish Machete reps on Hyrax 4.75 Pro-Line dual stage foams 2.0 Machete reps on BFG Krawlers 4.75 Pro-Line dual stage foams |
03-02-2023, 06:23 AM | #6 |
Quarry Creeper Join Date: Nov 2008 Location: grand junction
I've got a set of Treal wheels and 2 different chinese beadlocks all with proline tires no problem Sent from my SM-S901U using Tapatalk |
03-02-2023, 11:09 AM | #7 |
Well that's encouraging- Thanks- some guys said it would be a pretty tough deal to make fit - I'll get 'er dun- just waiting (hopefully) tax return then I'm off to my LHS thanks again
03-02-2023, 06:57 PM | #8 |
Quarry Creeper Join Date: Oct 2010 Location: So. Cal
Check out West Desert Wheeler on Youtube. See what tires he runs. He's in southern Utah and runs at Sand Hollow a lot.
03-02-2023, 07:39 PM | #9 |
Rock Crawler Join Date: Apr 2015 Location: San Marcos
In response to the Early Bronco tires (Axial's Falken Wildpeak M/T), they're a pretty solid tire. They do best in loose, deep terrain like sand, mud or loose dirt. They're decent on rocks too. But if you're shooting for a tire that will spend most of its time on rocks, there are a lot of better choices than the Falken. For all around off-roading or trail driving, the Falkens are an excellent choice. |
03-03-2023, 05:31 AM | #10 |
Thanks- yup so many options out there- time to study up just knowing my beadlocks will work out - Them prolines are looking better and better
03-03-2023, 06:21 AM | #11 |
If you do buy proline and do most of your crawling in hotter weather use the G8 compound the predator can be too soft Sent from my SM-S901U using Tapatalk |
03-04-2023, 04:38 PM | #12 |
got it - Thanks
03-11-2023, 06:09 AM | #13 |
RCC Addict Join Date: Jun 2006 Location: Durham, NC, USA
ChangQuish 1.9 BeadLocks w/ BFG K02 |
05-06-2023, 07:30 PM | #14 |
Rock Stacker Join Date: Apr 2023 Location: Sheboygan
I got a set of RC4WD Baja X on my “Que-T” wheels (tires cost more than the wheels LOL) They mounted without struggle or issue Sent from my iPhone using Tapatalk |
05-06-2023, 09:57 PM | #15 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
Proline tires used to be a pain to mount but seems like most wheels have adapted to them. At this point, I mostly run Vanquish wheels but have used many knockoffs from ebay and Amazon. Most of the time the tires mount up pretty easy but sometimes you get some that want to make your life miserable. Doesnt seem to be specific to any brand of tire or wheel. The biggest PITA are wagon wheels. The stamped steel wheels with no visible beadlock ring. Getting tires on those things will really test your patience. Oversized foams (like stock Proline) on narrow wheels are also a pain. |
Quality tire on chinese beadlock wheels - Similar Threads | ||||
are cheap chinese tire getting better | ferp420 | Tires and Wheels | 6 | 06-08-2019 07:39 PM |
Cheap Chinese beadlock problems | lasllcap@gmail.com | Tires and Wheels | 9 | 07-15-2018 09:36 PM |
How to mount tire on beadlock wheels? | psun786 | Newbie General | 1 | 08-12-2008 02:16 PM |
