Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tires and Wheels
Thread: how do you cut tire tread
Old 06-01-2004, 11:52 PM   #1
Default how do you cut tire tread
what is the best way to cut the tread on clodbuster tires? i already know what pattern i want to use, but how do you do it? what tool(s) do you use? how do you get the smooth look with out f*cking the tire all up?
risedrummer is offline   Reply With Quote
Old 06-02-2004, 06:43 AM   #2
Default Re: how do you cut tire tread
check http://www.mudcow.com/Page%2022.htm
ultralord is offline   Reply With Quote
Old 06-02-2004, 09:25 AM   #3
Dirt Addict
roktoy's Avatar
Location: Stumblin' thru the parking lot of an invisible 7-Eleven
I start with a pair of sharp, small wire cutters to remove most of the tread block. You can then clean up with a small Dremel sanding drum.
Jay
roktoy is offline   Reply With Quote
Old 06-02-2004, 12:28 PM   #4
I just used a dremel, since I didn't have the right kind of cutters. Made a bit of smoke, just wear goggles and a breather mask, and run a fan (or do it outside) Mine turned out ok. And yes, MARK THE TREAD.. I thought I was smarter than that but nope!
SR5Dave is offline   Reply With Quote
Old 06-02-2004, 07:15 PM   #5
thanks guys, i tried using air tools, like a grinder, and a cut off wheel, messy, and the tire does not like to stand still either. thanks again, oh, do you have any good patterns to try? that would help also.
Old 06-02-2004, 07:35 PM   #6
PapaGriz Yo
Grizzly4x4's Avatar
Check out the pics of SR5Dave's front tires here. That pattern seems to werk well.
http://www.rccrawler.com/postt331.html
Also look at www.mudcow.com
JK's tires are cut in much the same way.
Grizzly4x4 is offline   Reply With Quote
Old 06-03-2004, 12:34 AM   #7
The holes worked ok, but I got tired of the tires falling off the rim. I dont glue my tires because I would break everything in my axles! (Well, I imagine)
I'd reccomend against it. I punched a hole in once and figured I'd go for the gusto, the tires did sink in well and fold, but fell off the bead all the time.
Old 06-03-2004, 09:55 AM   #8
sounds like you need beadlocks. I have not heard of breaking axles because you glued the tires. I think you would break a driveshaft before the axles would go.
jeep_boy02 is offline   Reply With Quote
Old 06-03-2004, 10:34 AM   #9
Its a clod, there are no drivelines. My motors have SO much power that if im bound up the tires will start to slip in the rim, thats really the only time it does it. Trust me, if my tires were glued on, i'd have problems. They don't fall off with my makeshift foams in them, so no worries now, it was just those tires.
Old 06-17-2004, 03:15 PM   #10
I'm using an X-acto blad and making a sort of Baja Claw pattern (or Claw dawg pattern for the RC world). I haven't used the dremel yet maybe tonight. But man does it take a long time to cut them. I'm done with half of one tire. in two nights.
rckjeep is offline   Reply With Quote
Old 06-18-2004, 09:22 AM   #11
I found that the best way was to mount a "Friggin laser beam to a sharks head" and have him cut it for you.
DirkDigler is offline   Reply With Quote
Old 06-23-2004, 06:42 PM   #12
I did it by using flush side cutters to cut each tread as deep as possible. Then I used a dremel with sanding drum. Then sandpaper to smooth it out. Using a dremel or other grinder to shave the whole tread down would just make a huge mess. Like said before, wear a mask and safty googles.
CustomCrawler is offline   Reply With Quote
Old 06-23-2004, 11:59 PM   #13
im using an xacto knife and a straight edge razor blade, but i cant stress how important it is to keep it sharp, b/c after one tires the blade can be become pretty dull, but becarefull cause its kinda dangerous already sliced myself a few times.
oha nd after i use a dremel with a stoen wheel, i'm thinking about bringing out hte airgrinder to sand the rest of em down, might be faster.
oh and glue! cause i keep ripping the tires, mabey im a clutz?
extreme is offline   Reply With Quote
Old 06-27-2004, 07:30 PM   #14
Funney stuff.
Rye21 is offline   Reply With Quote
Old 06-27-2004, 09:18 PM   #15
aaa but you see the sharks never killed austin...in other word they didn't do what they were designed for so they might screw up your tire...so maybe that aint the best way ha ha ha
Ultima is offline   Reply With Quote
