Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tires and Wheels
Thread: Thought on the wheel narrowing
Old 06-02-2004, 11:15 PM   #1
Default Thought on the wheel narrowing
Could you not just splice a 1" (or whatever width you determined) section from the center of the rim and not even mess with the beads?? Is this being done already or can it not be done ? - maybe I just aint getting it???
jeep_boy02 is offline   Reply With Quote
Old 06-03-2004, 07:22 AM   #2
Colt Python/SR9c
TwistedCreations's Avatar
Default Re: Thought on the wheel narrowing
that's what i did to my Maxx axles. they have 2 air holes in them. so i made a line around it there and cut, then the back section i cut off to the first ring. now i can mount my tire anywhere from 3/4"-1 1/4".. i like the 3/4" better though. it really wraps the tread around
TwistedCreations is offline   Reply With Quote
Old 06-04-2004, 10:58 AM   #3
Sure. You can do it that way too. You just may loose some of the wheel's strength. The bond must be very strong between the two pieces.
DirkDigler is offline   Reply With Quote
Old 06-04-2004, 11:57 AM   #4
Colt Python/SR9c
now i look at it, why did i say maxx axles :? i meant the rims
Old 06-04-2004, 01:03 PM   #5
yeah I figured that - or you were just insane and had narrowed a maxx! hey now thats a project for somebody insnt it?
Old 02-01-2005, 01:23 PM   #6
Its been done
Artstu is offline   Reply With Quote
Old 02-01-2005, 02:16 PM   #7
Dirt Addict
roktoy's Avatar
Location: Stumblin' thru the parking lot of an invisible 7-Eleven
You didn't specify what kinda wheel, but that's how I've always
done my Clod wheels. The two pieces slip one inside the other perfectly.
Jay
roktoy is offline   Reply With Quote
Old 02-01-2005, 04:16 PM   #8
2006 2.2 National Champ
BENDER's Avatar
That's how I did my 40's. You have to sand the 2 halves on a flat surface so there is NO gaps between the two when you glue them. I think a lot depends on which wheel you are useing, as far as narrowing method goes.
BENDER is online now   Reply With Quote
Old 02-01-2005, 04:50 PM   #9
06 Super National Champ
JasonInAugusta's Avatar
I narrow mine on the Dremel press and use the center section that I remove as a sleeve to reinforce the bonded area.
JasonInAugusta is offline   Reply With Quote
Old 02-03-2005, 08:01 AM   #10
Where can I find some pictures of this? Thanks in advance.
mremax is offline   Reply With Quote
