Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tires and Wheels
Thread: BB's in tires?
Old 06-23-2004, 12:26 AM   #1
Default BB's in tires?
How many BB's are people putting in there tires as a starting point?
Thanks for the info,
Fireman
fireman is offline   Reply With Quote
Old 06-23-2004, 01:27 AM   #2
PapaGriz Yo
Grizzly4x4's Avatar
Default Re: BB's in tires?
I tried 1.5 35mm film canisters in each tire and found it to be too much. I think that with a Clod too many bb's really hurts because you only have one motor driving the front axle. With a shaftie and dual motors you can get away with more bb's.
I plan to try one film cannister in each tire and see how that does.
Good luck!
Grizzly4x4 is offline   Reply With Quote
Old 06-23-2004, 10:45 AM   #3
I had a pound of bb's in each tire and recently went to 2 pounds, which really proved to be too much. I am going back to one pound in the fronts and a half pound in the rear. My god.......it sounds like I'm ordering meat from a deli!!!!!!
One last note: I may ditch the Kongs in favor of the new KROCK tires. I can't wait to try them out to see if they are worth. I have big plans for change if they work well.
DirkDigler is offline   Reply With Quote
Old 06-23-2004, 11:30 AM   #4
I am going to try the clod "D" tire when it's available. For know I am going to use narrowed clod tires. I am going to try the BB's.
Fireman
Old 06-23-2004, 12:42 PM   #5
so how you getting the bb's in and out of the tires if they are glued? other that breaking the glue bead.
ultralord is offline   Reply With Quote
Old 06-23-2004, 12:47 PM   #6
PapaGriz Yo
Grizzly4x4's Avatar
My bb tires are MGT's with only the inner bead glued to the rim. The tire fits tight enough that they do not slip even without glue, but I left it unglued so that I could experiment with the bb's.
Old 06-23-2004, 01:34 PM   #7
Not that I am doing this every day to add and remove bb's but I just cut a very small slit into the tires tread, squeeze it open a bit and pour them in or out. Break out the IC-2000 and patch it up when done! Never had it tear back open.
Old 06-23-2004, 01:35 PM   #8
Ace
C-section bb removal!
You don't pass up any chance to cut,mame and glue up tires do ya?
:P
Ace is offline   Reply With Quote
Old 06-23-2004, 02:24 PM   #9
Exactally!!
Old 06-25-2004, 04:29 PM   #10
RIP Buster
badger's Avatar
I use 1,658,492,023 bb's in my front tires and 45,822,576 bb's in my rear tires.
I am running low in my red rider bb gun so the rear tires might be getting a little lighter!
badger is online now   Reply With Quote
Old 06-29-2004, 01:01 PM   #11
what do bb's do to the tire? and dont they get annoying when they keep rolling around with the plastic or aluminum wheels
bajabeast is offline   Reply With Quote
Old 06-30-2004, 08:29 AM   #12
They add weight that sits directly on the ground.
They are not annoying when they help you climb vertically!!!!
Old 07-14-2004, 05:39 PM   #13
Has anyone tried using wheel weights. the stick on type? I'm going to try it tonight.
spinner is offline   Reply With Quote
