Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tires and Wheels
Thread: Question for Dirk
Old 06-23-2004, 06:23 AM   #1
Default Question for Dirk
what CA glue did you use that was rubberized? where can you get that stuff?
ultralord is offline   Reply With Quote
Old 06-23-2004, 10:00 AM   #2
Guest
Posts: n/a
Default Re: Question for Dirk
I use IC-2000 from Hobbytown.
Old 06-23-2004, 10:02 AM   #3
PapaGriz Yo
Grizzly4x4's Avatar
Whoops, that was me.
Grizzly4x4 is offline   Reply With Quote
Old 06-23-2004, 10:37 AM   #4
is it flexible ? i have a clod tire that has a split in the sidewall. dont want to just scrap the tire
Old 06-23-2004, 10:40 AM   #5
I used regular CA, rubberized IC-2000 on the outside
and Goop Sealer on the inside.
DirkDigler is offline   Reply With Quote
Old 06-23-2004, 10:43 AM   #6
cool, ill have to see if i can pick some up and try that.
Old 06-23-2004, 11:56 AM   #7
buzzed to the hobby store at lunch and amazingly they had it. have to give it a shot tonight.
