Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Killer new Rock Rings from 62Pyro
Old 08-29-2007, 08:44 PM   #1
06 Super National Champ
JasonInAugusta's Avatar
Default Killer new Rock Rings from 62Pyro
I've had these for a little while, Pyro said to post'm up.
Check'm out.
These were made for my 2.2 Suicide Sally build.
Designed to work with any RC4WD wheel that uses 12 bolt rock rings.
Also designed to allow the use of M2Ks or Moabs without needing to modify the wheel. They're stepped on the back side of each ring (front and rear rings included) so they compress the bead more than a standard beadlock ring. They lock the bead in place, no doubt about it.
When you install these rings you will need to tighten the screws in a criss-cross pattern a few times, just as you do with 1:1 beadlocks. Not doing so will leave loose screws.
JasonInAugusta is offline   Reply With Quote
Old 08-29-2007, 08:49 PM   #2
Wow they look sick, so i take it pyro will be selling these eventually?
HITMAN is offline   Reply With Quote
Old 08-29-2007, 08:50 PM   #3
Hella sweet!
microgoat is offline   Reply With Quote
Old 08-29-2007, 08:50 PM   #4
Ultimate RC Decals
BOWTIE's Avatar
gotta hand it to 62pyro, he always does top notch work.
BOWTIE is offline   Reply With Quote
Old 08-29-2007, 08:55 PM   #5
RPP Hobby's Avatar
Those are sweet
RPP Hobby is offline   Reply With Quote
Old 08-29-2007, 08:58 PM   #6
~THE SCALE SHOP~
what wheels are those second ones?
STANG KILLA SS is offline   Reply With Quote
Old 08-29-2007, 08:59 PM   #7
RC4WD 2.2 Rockstars
http://rc4wdstore.com/product_info.p...roducts_id=648
Old 08-29-2007, 09:02 PM   #8
man those look killer
aggressivellc is offline   Reply With Quote
Old 08-29-2007, 09:07 PM   #9
Keep it real
Tanis's Avatar
So I take it these rings will allow my BL35's to finally hold a masher? Sweet. Looking forward to a set.
Tanis is offline   Reply With Quote
Old 08-29-2007, 09:08 PM   #10
dezfan's Avatar
Holy poopie! Those rings are absolutely incredible!
dezfan is offline   Reply With Quote
Old 08-29-2007, 09:35 PM   #11
Yup, yup.
I should also add that there are no sharp corners to cut into the tire. The only square "shoulders" on the rings are around the through holes and the inside detail area. No sharp corners where they'll contact the tire.
Old 08-29-2007, 09:42 PM   #12
The first one kinda looks like a snow flake. I think I'll get the Rock Stars.
Nice rings.
Thorsteenster is offline   Reply With Quote
Old 08-29-2007, 09:45 PM   #13
Nice rings.
First ones are the 12 bolt version of the wheels used on this rig. Dan used the 8 bolt wheels.
Old 08-29-2007, 09:53 PM   #14
666
MODERHATER™
666's Avatar
A.D.D. Isn't that thing done yet?
And yes those rings are sick, now that Pat knows he can do RC4WD rims, I guess I need some!
666 is offline   Reply With Quote
Old 08-29-2007, 10:04 PM   #15
DUDE's Avatar
I want some, 8 bolt please.
DUDE is offline   Reply With Quote
Old 08-29-2007, 10:22 PM   #16
Picky Fab'r/Acetal Junky
Offroader5's Avatar
Those look awesome! How thick are they...they look pretty beefy?
Offroader5 is offline   Reply With Quote
Old 08-29-2007, 11:16 PM   #17
1/8"
Old 08-29-2007, 11:59 PM   #18
Nice job...
Old 08-30-2007, 05:24 AM   #19
Another great product from 62Pyro.
Nice job Pat!!!!
Rckcrwlr is offline   Reply With Quote
Old 08-30-2007, 05:26 AM   #20
ΜΟΛΩΝ ΛΑΒΕ
chip cross's Avatar
very nice
chip cross is offline   Reply With Quote
