Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tires and Wheels
Thread: may have cut too much?
Old 06-30-2004, 03:40 PM   #1
Default may have cut too much?
So, I cut my stock TXT tires to somewhat of a Baja Claw tread pattern while building my rock rig. Now that it works(sorta) I'm noticing that the tires flex to almost the rim. Should I rig up some foams?
rckjeep is offline   Reply With Quote
Old 06-30-2004, 03:59 PM   #2
Default Re: may have cut too much?
I did the same to my stock emaxx tires and they look like Low Profile tires....I guess you could fab some foam up...I also have issues when i try to drive at high speeds it's very unstable...
I dnt care thou I just cant see my self spending $60.00 on tires im going to cut up...i still cant find an ideal crawling tire..
bulletproofcustoms is offline   Reply With Quote
Old 07-01-2004, 12:06 AM   #3
thats whats going to happen, just put like a 1.5 inch foam in it and that should be good.
Ultima is offline   Reply With Quote
