Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Narrow Positive offset rims
Old 01-09-2008, 11:28 AM   #1
Default Narrow Positive offset rims
With this rim
http://www.tcscrawlers.com/VF-Assass...t-p-16733.html
Or this rim
http://rc4wdstore.com/product_info.p...roducts_id=262
I should have the same positve back spacing. Seeing as how they are both made to reduce the track width of a clod/ wheely king axle.
Would I be correct, or am I totally off base.
hitman46mod is offline   Reply With Quote
Old 01-09-2008, 01:27 PM   #2
On the lookout for Rocks
constantmotion's Avatar
They may have the same offset but the VF Assassins are narrower giving you a narrower track width than the RC4WDs.
constantmotion is offline   Reply With Quote
Old 01-09-2008, 01:30 PM   #3
~THE SCALE SHOP~
the rc4wds you posted look to have nearly a 0 offset, (ie right in the middle of the wheels centerline)
STANG KILLA SS is offline   Reply With Quote
Old 01-09-2008, 10:05 PM   #4
Thank you both. I need some informed opinions. To make sure I was not jumping to conclusions.
Old 01-10-2008, 05:25 AM   #5
As I posted before...I have the VF Stalkers and there is a 1/4" from the front of the wheel to the face of the hex. Your not going to get any narrower than that...
Rckcrwlr is offline   Reply With Quote
Old 01-10-2008, 05:38 AM   #6
How narrow of a Track width do you need? I've made a few custom sets that will give you a narrow track width then any of those. But they are not beadlocks. You would have to Glue your tires.
Old 01-10-2008, 08:22 AM   #7
SCALE PERFORMANCE PARTS
Locked Up's Avatar
I did the same thing with some rustler wheels:
http://www.patricksnorton.com/WK/tec...offsetrims.php
You can narrow them as much as you want/need from the backside and they are about $8 for 2
Locked Up is offline   Reply With Quote
Old 01-10-2008, 08:26 AM   #8
What About The New Pro-line Narrow 2.2 Crawler Wheels?
What Kinda Offset Do They Have?
DonkeyPunch is offline   Reply With Quote
Old 01-10-2008, 06:52 PM   #9
This doesn't look in your favor to me....
Calderwood is offline   Reply With Quote
Old 01-10-2008, 06:56 PM   #10
Here are my stalkers
Old 01-10-2008, 07:05 PM   #11
Maybe tcs has the wrong picture?
Old 01-10-2008, 07:26 PM   #12
~THE SCALE SHOP~
the stalkers pull the wheel IN.
my Assassins, push the wheel OUT.
