Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: Powdercoating
Old 01-18-2008, 06:00 PM   #1
Default Powdercoating
Does anyone have or know someone who has the following...
http://www.harborfreight.com/cpi/cta...emnumber=94244
http://www.harborfreight.com/cpi/cta...emnumber=46300
I'm looking into getting a small powder coating setup and was wondering if anyone knew anything about those.
4u2nv is offline   Reply With Quote
Old 01-18-2008, 06:19 PM   #2
That one's not bad at all, I have used it allot with no real problems.
You should check this one out.
http://www.powderbuythepound.com/cat...roducts_id=359
I've heard good things about it , and you cant beat the price
BECKWORKS is offline   Reply With Quote
Old 01-18-2008, 06:39 PM   #3
Yes, and a quick search for "powder coating" turns up quite a few threads about it, including this one that I did a step by step picture howto at the request of Jason.
Cloak is offline   Reply With Quote
Old 01-18-2008, 07:34 PM   #4
Jason asked you? The hell was he smoking?
ColquittCustom405 is offline   Reply With Quote
Old 01-18-2008, 07:36 PM   #5
I did search and didn't find any info on the oven... that's my main concern.
Old 01-18-2008, 09:56 PM   #6
The gun works good but waists alot of powder because of the larger opening as far as using it for small chassis like we do.. But if you fab up a "catch" for the unused poweder you can recycle it.
The over I hear is good too.
It's a decent size inside 18X18X18
And it runs on 110V so you won't need a 220 like you would for a normal oven.
Price is about the same as adding a 220 box to the garage though. (from what I was quoted may cost more or less in your area)
I'm sure this seals and holds heat better than a conventional oven and if you ever plan on doing any pottery stuff you can use this as well..:?.
Double J is offline   Reply With Quote
Old 01-22-2008, 06:08 PM   #7
Default pay for it
dont you need to powder coat in a special paint booth. For neg. or positive charge.
BASSPROKVD is offline   Reply With Quote
Old 01-29-2008, 06:49 AM   #8
On the lookout for Rocks
constantmotion's Avatar
You can powder coating basically anywhere.....you'll just get powder everywhere. The fumes/dust are only bad when curing......still would recommend a dust mask or respirator.
constantmotion is offline   Reply With Quote
Old 01-29-2008, 09:04 AM   #9
It is really a good idea to wear a respirator when you're near the curing oven. Those fumes are real toxic.
