02-02-2008, 09:59 PM | #1 |
Quarry Creeper Join Date: Sep 2007 Location: Duchesne
| need some help with brazing
I noticed that you guys braze your tube chassis together. but the question that I have is how hot do you have to get the the tube and brazing rod for it to braze properly? thanks.
02-02-2008, 11:09 PM | #2 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
glowing, the only way to know for sure is to heat it up and touch it with brazing rod if it melts you're good |
02-03-2008, 10:53 AM | #3 |
would 2500 degrees do the trick?
02-03-2008, 12:00 PM | #4 |
Rock Crawler Join Date: Dec 2005 Location: West Omaha
Mapp gas gets to 2509 I think it was and it is what most people use, so yeah.
02-03-2008, 12:09 PM | #5 |
cool I might order a torch for tower then thanks.
02-03-2008, 12:16 PM | #6 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
02-03-2008, 01:48 PM | #7 |
Quarry Creeper Join Date: Nov 2007 Location: barre
and try not to over heat the tube it will turn the joints black i get the tube red hot and when the braze starts to melt o move the torch away abit to keep it from over heating have fun its not as hard as it looks
02-03-2008, 05:20 PM | #8 |
Newbie Join Date: Sep 2007 Location: in a house
I found that getting the tubing med. hot then melting a little solder onto the joint then heat until that solder BB loses its surface tension and fills the joint. I hope that makes sense.
02-03-2008, 05:50 PM | #9 |
ok thanks for the help guys I think that my dad has a propane torch somewhere I will have to go over and see if I can find it. thanks again.
