03-11-2008, 11:20 AM | #1 |
I wanna be Dave Join Date: Dec 2005 Location: Tax Nation
| 8 easy steps to making suspension links How to Guide Supplies needed: 3/16 Brakeline 6-32 Dubro Ball links 6-32 All-thread 6-32 Tap Tube cutter Vise Grips Cutoff tool (Dremel, nips etc) Measuring device Marker (Thinner the better) Drill or Tap Handle Step 1 Place the 6-32 Ball Links where you need them and measure the distance between the 2 Step 2 Measure the Brakeline to the desired length and mark Step 3 Using the Vice Grips to hold the brakeline, use the tube cutter to cut the brakeline to the desired length Step 4 Using the 6-32 tap in either a Drill or a tap handle, tap each end of the brakeline. A depth of anywhere from ¼”-1/2” is good Step 5 Thread the all-thread into the tapped brakeline… I find it best to use the Vice Grips to hold the brakeline Step 6 Cut the all-thread, again this is by personal preference, any where from ¼” to 3/16” sticking out of the brakeline is good Step 7 Thread the Dubro 6-32 Ball links on Step 8 Attach the completed links in the desired position Hope this answers some of the questions I get. Also available @ http://www.suburbanchicagorockcrawlers.com/ in the tech section |
03-11-2008, 01:29 PM | #2 |
Rock Stacker Join Date: Jan 2008 Location: Edmonton
Looks really good, but FYI, using a tap in a drill is a risky deal. Taps are notoriously brittle, and when you're using the drill, you can't "feel" how much force is being put on the tap. Broken taps aren't a huge problem in something as simple as a link, but it's a pain if you have to run back to the hardware store to get another one in the middle of a project. I always tap by hand, maybe use a drill press to get the tap started straight, but that's it. It depends on the material, but usually 1/2 to 1 turn in, followed by 1/4 turn out, to clear the cutting teeth, seems to work good. You develop a feel for it after doing a bunch. |
03-11-2008, 02:01 PM | #3 |
everytime I use a tap handle I snap the tap, when I use the drill I very very rarely do...I normally end up throwing away the tap because its dull. At this point I have prolly made about 75' worth of links in this manner. The main thing you have to watch with using a tap in a drill with brakeline is making sure you get it started straight.
03-11-2008, 02:04 PM | #4 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
I use 1/4" SS tubing and 4mm SS allthread. No need to tap and strong as hell.
03-11-2008, 02:20 PM | #5 |
Very nice writeup, thanks for doing that jetboat. Couple comments from me: I use a drill for tapping my links as well, works great. Just use lots of oil and don't force it. When I cut my brake line, I put the brakeline in my cordless drill. Then I put the tube cutter on (I use the same one as you), then I spin the brakeline with the drill with one hand and crank the tube cutter in with the other. Works great and fast for me. |
03-11-2008, 02:23 PM | #6 |
| More work but hey why not.
03-11-2008, 02:36 PM | #7 |
Newbie Join Date: Dec 2007 Location: York
cool write up, im going to make links for my tuber this week thanks
03-11-2008, 03:30 PM | #8 |
03-11-2008, 04:50 PM | #9 |
Hey, if the drill works for you that's great. I just wanted to put a bit of a caveat out there in case someone new to this chucks up a tap and tries to tap his link at full speed or something. Slow and straight, its probably just as good as by hand, and a lot easier on the wrist. Hope I didn't piss anyone off, wasn't my intention.
03-11-2008, 04:56 PM | #10 | |
03-11-2008, 08:33 PM | #11 |
one question for ya jetboat wouldn't it be stronger to get the next size down in all thread and slide the brake tube over that? I was thinking about that after my first post
03-12-2008, 08:20 AM | #12 |
I have only ever bent 1 link I made in this manner, That was on a very heavy super that took about a 15' fall. The problem with going smaller with the all-thread is that you then have to step down with the ball links and that is where I have always seen problems. The best parts about this method are that its fast and cheap. I can make a link in under 2 mins. Firebat, Didnt tick me off... I included in the directions to use either a drill or tap handle. I prefer a drill. |
