Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tools, and Procedures
Thread: bending aluminum
Old 07-02-2005, 09:19 PM   #1
Default bending aluminum
what's the best way to go about bending aluminum? I know its probably gonna weaken it, but when I need to bend some semi-thin aluminum, what's the best way to go about it?? Thanx, Wes
wslytoy is offline   Reply With Quote
Old 07-02-2005, 09:37 PM   #2
Either put it in a vice and push on it, or use a sheet metal brake if it is thin enough. Don't use a brake if the metal is semi thick (like over .050") or else it will fracture when you try to bend it.
CustomCrawler is offline   Reply With Quote
Old 07-02-2005, 10:29 PM   #3
06 Super National Champ
JasonInAugusta's Avatar
I use a vice and rubber mallet.
JasonInAugusta is offline   Reply With Quote
Old 07-02-2005, 11:49 PM   #4
2006 2.2 National Champ
BENDER's Avatar
That's my method too.
You can bend some pretty tight angles in it, if you take your time. If you try to bend it all in one shot that's usually when it cracks. Alot depends on the grade of aluminum too.
BENDER is offline   Reply With Quote
Old 07-03-2005, 02:09 AM   #5
Originally Posted by ILoveRCRockCrawlin
and why is this in the tires and wheels section??????
that's really strange, I posted in general. hmmmm computers, what can I say.....
Old 07-03-2005, 08:51 AM   #6
Ace
6061 doesn't bend very well, it stress cracks like crazy.
5052 bends like a dream.
If your bending a sharp 90*, take the time to get 5052. The 6061 might bend, but it'll fall apart eventually.
Don't ask how I know!
Ace is offline   Reply With Quote
Old 07-03-2005, 01:45 PM   #7
Is 5052 strong enough for bends and then later on maybe some curb impacts? LOL!! I considered gettin something softer but I don't want it to be fragile either. Thanx, Wes
Old 07-26-2005, 12:56 PM   #8
With 6061, could you mill into it a low spot along the line you want to bend and be successful, or will it still crack? Maybe applying a small amount of heat to that area you wish to bend (I know aluminum can deform pretty easily, I was thinking of using a saudering iron along the line I want to bend, and then bending some, heating, bending, heating, bending). This'd be with 1/8" 6061, since I have about 4 feet of the stuff.
Plays_with_Toys is offline   Reply With Quote
Old 07-26-2005, 09:00 PM   #9
I was thinkin about that, but I was scared it might make it brittle. I don't know for sure, maybe some1 w/ some experience/knowledge will chime in. BTW, you wouldn't wanna get rid of some of that aluminum would you? lol, I need some for a chassis and my LHS SUX!
Old 07-26-2005, 09:54 PM   #10
Well, technically, its at my old highschool, and I need to speak to the shop teacher about getting it back (I donated it for other kids' projects, but no one has since touched it). He doesn't get back to the school until august 16th.
I bought my aluminum from a metal scrap yard. It was a junkyard with every type of block, pallet, circular blocks, extrusion, etc... I think I got ripped though. I bought my 2x5ftx 1/8" for $43. I've heard people buying it much cheaper.
Old 07-27-2005, 04:09 AM   #11
BENDER's Avatar
I'm not sure if scribing your bend line, with an endmill, in the stock will help or not. I know heating it gently with a torch on LOW will anneal it, making it more flexible. I've only tried it once, but blacken the aluminum with a torch sweeping back and forth across your projected bend line a few passes at a time. It should become more mallable (sp) the more you do it.
I've never really tried this with an R/C application......................but I did stay at a Holiday Inn last night.
Old 07-27-2005, 10:11 AM   #12
I plead ignorance here... (and in many other things as well...)
2 Questions:
-What about using a tubing bender (ie; the coiled spring type that does not allow the tube to flatten at the radius)? I've been looking, but the smallest I can presently get my hands on is 3/8".
-I put my hands onto 1/4" and 3/16" stainless tubing. I'd like to make high clearance links out of it, figuring that it will bend much easier. My problem is that when I try to tap it... well, it doesn't tap easily. Aluminum I can pretty much grab in the soft jaws of a vice and tap like butter. Stainless is so hard to tap, I either spin it in the jaws or nearly break my tap (which I'd like to avoid ) Any suggestions?
radishkid is offline   Reply With Quote
Old 07-27-2005, 01:16 PM   #13
BENDER's Avatar
2 Questions:
I'm not sure about the tubing benders, I've never really tried using one.
Do you have some sort of cutting oil for the tap, try to find some dark high-sulfer cutting oil for pipe threading. Moly Dee is a good one, crap stinks a little but it works great.
Old 07-27-2005, 02:31 PM   #14
i use a bar of soap just rub the treads cheap too
Artstu is offline   Reply With Quote
Old 07-28-2005, 11:34 PM   #15
I use one of these;
http://www.harborfreight.com/cpi/cta...emnumber=39103
David
Davkin is offline   Reply With Quote
Old 07-31-2005, 08:18 PM   #16
i heat the alum till the soot burns off and have had no problems with cracking unless i go past 90 deg.i have no idea about the sheet im useing its old street signs i get from construction sites the price is right [free].
thatguy is offline   Reply With Quote
