Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tools, and Procedures
Thread: dremel
Old 07-04-2005, 07:20 PM   #1
Default dremel
is the dremel 400 series xpr a good tool to use to cut chassis plates?
what attachment would you use?
romeo26 is offline   Reply With Quote
Old 07-04-2005, 08:08 PM   #2
06 Super National Champ
JasonInAugusta's Avatar
A rotary tool will work to cut aluminum (I just used one to cut steel using the reinforced cut-off wheel), and case modders have been using them for years, but you'll get better results with a band saw, hack saw, coping saw, scroll saw, etc.
Kind of hard to get nice, even cuts with a cut-off wheel. Sure, you can do it, but you'll find yourself spending a good bit of time filing the edges so they don't look like a rabid badger gnawed the chassis out for you.
JasonInAugusta is offline   Reply With Quote
Old 07-04-2005, 09:46 PM   #3
Colt Python/SR9c
TwistedCreations's Avatar
yeah this is a piece I just cut out tonight using a cutoff wheel and a drill press w/hole saw for center....
it does the job, but takes a little more time and still looks like a horses' rear
man do i need a mill
TwistedCreations is offline   Reply With Quote
Old 07-05-2005, 12:46 PM   #4
Ive had pretty good results with a dremel.... Ive made aluminum motor mounts that dont look too shabby, and dremels are also excellent so many other things (im not saying band saws, table saws etc. arent but some come with a hefty price) and the dremel 400 XPR is only 69.99.... dremel also has a mini saw attachment
http://www.homedepot.com/prel80/HDUS...gmj.0&MID=9876
PastryLikeDood is offline   Reply With Quote
Old 07-05-2005, 06:29 PM   #5
okay thats cool ill get it then. i just need it for makin stuff like chassi main thing, and car stuff. but mostly around the house, case modding, and r/c.
and twistedcreations
that looks way better then when i made my hpi nmt chassi with my friends cordless dremel, iam getting it corded (this is a good idea rite?)
is aluminum good to make a chassi from?
Old 07-05-2005, 10:20 PM   #6
Colt Python/SR9c
yes, get one with a cord. cordless suck.
alum will be just fine for a chassis
