| | #1 |
| Quarry Creeper Join Date: Jan 2005 Location: Orem, UT
| I have a (5 month old) dremel model #275 with 35,000 rpm. Today while narrowing my rims the dremel got pretty hot, so I set it down for a several minutes and when I came back to finish the last rim and it wouldn't turn on. And after an hour or so it is still dead. Does anyone know if I just burned it up and need to get a new one? Or, is there something that I can do to fix it? Thanks! --BMW |
| Sponsored Links | |
| | #2 |
| 2006 2.2 National Champ ![]() Join Date: Dec 2004 Location: Driving my R/C rototiller
| I think you can replace the brushes in it, I've never done it personally though. |
| | #3 |
| RCC Addict ![]() Join Date: Jan 2004 Location: Louisville Kentucky
| I had almost the exact same problem. I was using it (a 275 just like yours) and turned it off. I noticed the on/off switch felt strange. When I turned it back on I got nothing. I even took the thing apart to see if I could find a missing contact or something but nothing? The bad part was that this was the 2nd time I used it |
| | #4 |
| 06 Super National Champ ![]() Join Date: Jun 2004 Location: Tennessee
| Dremel has a 5 year warranty on their tools. Q: Where do I send my Dremel tools when they need to be repaired? A: When forwarding your tool, please carefully package the tool only (not the kit box or accessories). If sending a cordless tool, please include both the tool and charger. Be sure to include a copy of your dated proof of purchase, a written statement describing the problem, and your name, address and daytime telephone number. We recommend that the package be returned insured against loss or in-transit damage for which we cannot be held responsible. Please send the package to one of the following: U.S.A.: Dremel Service Center 4915 21st Street Racine, WI 53406 Phone: 1-800-437-3635 1-262-554-1390 Other authorized U.S. service centers: Dremel Authorized Service 4631 E. Sunny Dunes Palm Springs, CA 92264 Phone: 1-800-275-2052 1-760-327-3003 |
| | #5 |
| I doubt very much that I still have the receipt. Crap! |
| | #6 |
| Rock Crawler Join Date: Apr 2004 Location: Longmont, CO
| My first dremel lasted about 10 years of very hard use. Then one day I was really working it hard and the windings melted (burnt epoxy). No biggie, it lasted 10 years. Bought another one and I had it about 1 month and dropped it about 10 inches on the spindle. That shoved the armature shaft up and broke internal plastic parts. I bought a Black and Decker (I think) RTX and have been happy with it. |
| | #7 |
| RCC Addict Join Date: Apr 2004 Location: Cincinnati Ohio
| My dremel lost is speed controller. It would only turn on HIGH and off. Took it apart and saw the switch was burnt up. Went to Target and bought a new one, swapped the switch, and returned it Now after a few weeks the "new" switch is doing the same thing. |
| | #8 |
| Pebble Pounder Join Date: Nov 2004 Location: P-Town!
| Adam, thats called karma |
| | #9 | |
| Rock Stacker Join Date: May 2005 Location: Vancouver
| | #10 |
| Pebble Pounder Join Date: Mar 2005 Location: Utah
| I had my first Dremel for 12 years then it finally gave out. Bought another, burnt it out in a couple weeks, then another, same thing. I got my money back from HD the second time and went to HF and bought a $20 Chicago Electric moto tool and it's worked like a champ for 5 years, and I often work it quite hard. The only problem is, at least at the time there were no variable chucks available for it, so I can't hold drill bits much smaller than 1/8" with it. I have a small cordless Dremel I use for handling small bits and small jobs, but I baby it. Dremel really went downhill a few years ago. David |
| | #11 |
| I dont usually return things like that. It's just that I had problems with my dremel before (diffrent problem, it just died) and I was pissed that it went out again. I checked the brushes as well and they were fine. The dremel does get extremely hot when using it hard. |
| | #12 |
| Funny thing happened. I plugged in my dremel just before I was going to toss it, and it made a little noise, then quit. I unplugged and replugged with no response from the dremel. Then I tapped it against the work bench and it made more noise and started working. So I smacked it a few times untill the RPMs came up and now it works just like it did. But who knows when it will crap out again. Untill then I will just baby it till I get a B&D like Ace. --BMW |
| | #13 |
| Quarry Creeper Join Date: Jul 2004 Location: Lake Mary
| my old dremel that I've had for years is still going strong, but when I was on the road with my last job I went through about 3 of the newer dremels 1 black&decker and 1 no name cheapy. set off a fire alarm with the b&d, yeah I cooked that one good. for any heavy work I use my pneumatic die grinder instead. |
| | #14 |
| Rock Stacker Join Date: Jun 2005 Location: anaheim
| so are the new Dremel 400 Series XPR bad? |
| | #15 |
| Rock Crawler ![]() Join Date: Jan 2004 Location: chicago
| i burn up a dremel once a year it seems. i just buy the cheap craftsmans and run them till they die. cutting tires is extremely hard on the little guys. when i cut my mammoths a few years ago i literally wrapped it in a rag to keep it from burning my hands, which in turn made the dremel very unhappy. |
| | #16 |
| Quarry Creeper Join Date: Nov 2004 Location: Elkton/Newark
| I just use an electric die-grinder (Falcon if I remember right) with a 1/2hp motor, exchangeable head, and 5 foot flexible drive cable. Heh heh, it even has a variable speed pedal. Only hitch is that in a lot of situations requiring maneuvering the tool, the cable binds and the motor bogs down a little; inner guilt trip, don't want to wear it out prematurely, it's only like 15 years old |
| Thread Tools | |
| Display Modes | |
