08-15-2008, 06:34 AM | #1 |
Powered by Awesome Join Date: Sep 2004 Location: Parker, Colorado
| Band saw blades?
So, was in Lowes last night and picked up a 10" Hitatchi with tilt and such for cutting out chassis and bracets and such.... just to make life easier. Now, this stupid thing requires a 63-1/2" x 1/4 - 3/8 blade... it came with a 6 Tooth Per Inch blade which i assume is for wood. Now, after hours of searching (no kidding - about 3 hours) for a metal cutting blade, i found one at the Tool Barn for 15 bucks a pop. cant find one anywhere else. so my question is this: Can the 6tpi blade cut steel plate that is about 1/16 thick? Anyone know where else to get a 63-1/2" metal cutting blade, at least 10 tpi? What are you guys using? |
08-15-2008, 07:17 AM | #2 |
Pebble Pounder Join Date: Jun 2008 Location: Central Florida
The problem with wood band saws is they don't run slow enough to cut steel. Therefore, you're blade choices are pretty much limited to wood blades. The cheapest way to get set up with a good metal cutting band saw is to buy one of the import " horizontal cutoff saws". The saw can be used in the upright position just like a regular bandsaw. This one will work great: http://www.harborfreight.com/cpi/cta...emnumber=93762 |
08-15-2008, 07:28 AM | #3 |
RCC Addict Join Date: Nov 2007 Location: in the woods
08-15-2008, 11:26 AM | #4 |
i just found Olson Band Saw blades.. they can custom make to size and whatnot.. i found a guy on ebay who is an authorized dealer.. picked up 3 18TPI blades 63-1/2 x 3.8 for $9 each and like $4 in shipping.
08-15-2008, 01:13 PM | #5 |
Rock Crawler Join Date: Jul 2005 Location: Central Coast
I had this same problem, wood cutting bandsaw and wood blades only. I was able to find a blade (can't remember how many tpi it was at the moment) but I think it was a half inch blade so its fairly stout. I was wondering if adding some kind of inline resistance to the motor to slow it down would be a feasible idea? Maybe an adjustable switch for varying speeds. I don't know. |
08-15-2008, 01:15 PM | #6 |
08-15-2008, 01:18 PM | #7 | |
With a small AC motor it would have to be done with belts or gearing. It would be easier and probably cheaper to buy the metal cutting saw. | |
08-15-2008, 01:48 PM | #8 |
08-15-2008, 01:49 PM | #9 |
this is what i bought: http://cgi.ebay.com/Band-Saw-Blade-6...742.m153.l1262 you can specify which ones you would like! for example.. (pulled from his add) This blade is available in the following grades: 1/8 inch width with 14 teeth per inch, 0.018 inch thick, for tight scroll cutting (minimum radius 1/4 inch) in wood, plywood and composites. Fine finish. 1/4 inch width with 8 teeth per inch, 0.014 inch thick, for general purpose contour cutting (minimum radius 3/4 inch) in wood 3/8 inch thick plus. Fast, smooth cuts. 1/4 inch width with 14 teeth per inch, 0.014 inch thick, for general purpose cutting (minimum radius 3/4 inch) in thinner stock 1/4 inch or more. Fine finish. 3/8 inch width with 6 teeth per inch, 0.014 inch thick, for general purpose cutting in wood 1/2 to 3 inch thick. Fast cuts, medium finish (minimum radius 1 1/2 inch). This blade is also available in the following metal and plastic cutting grade for $11.00. This is a Thin Kerf Hard Edge Flex Back (TK) blade made from high carbon steel with harder teeth. 3/8 inch width with 18 teeth per inch, 0.014 inch thick, for non-ferrous metals and plastic. |
08-15-2008, 04:05 PM | #10 | |
RCC Addict Join Date: Aug 2005 Location: VARCOR
I plan to take it apart at some point soon and find a replacement sheave and belt to slow it down some. | |
08-16-2008, 12:57 AM | #11 |
Rock Crawler Join Date: Apr 2008 Location: On the Snap on truck
Get a good bimetal varitooth blade for cutting metal, I use 10/14 on my Jet 5x6 bandsaw- very similar to the one sold by harborfreight,just much better quality. I bought my blades from this guy - http://stores.ebay.com/Mania-of-Meta...Q3amesstQQtZkm - you'll have to ask him for bimetal he no longer list them Bimetal, super cheap, cost just as much as my non bimetal olsons. One thing you can try but will not be good for the motor on long runs is rig up a "fan" dimmer switch with a plug and outlet and adjust the switch to slow your speed down,make sure you use a "fan" dimmer switch, regular light dimmers can not handle the power, I did this to my benchgrinder,works fine, just would not do it for a long time without cool down periods, 5 years on the bench grinder and never had a problem yet- knock on wood - Last edited by Joat; 08-16-2008 at 02:41 AM. |
08-16-2008, 01:51 AM | #12 | |
I recently saw a lot of different size, and width pulleys and stuff that may be useable at ACE hardware. | |
08-16-2008, 07:14 AM | #13 |
If you guys are going to run the high speed saws, you might want to look into carbide grit blades. I know 3M makes them. Maybe one of the blade suppliers previously mentioned can make them up. I've had one for years that I use to cut carbon fiber and other abraisive materials. They should cut thin steel as well. They will clog up with aluminum though :( The blade I have was expensive but it's paid for itself many times over |
08-16-2008, 01:05 PM | #14 | |
08-16-2008, 07:42 PM | #15 | |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
