08-23-2008, 10:08 PM | #1 |
Quarry Creeper Join Date: Mar 2007 Location: northern utah
| bending pipe with ice?
hey guys i just watched a "how its made" on tv and they were making trumpets, to make some of the bends with out creasing the tubing they filled them with water and froze it and then bent it to keep it from crushing. i havent personally tried this but thought it might work on some of the tight bends we do on crawlers |
08-23-2008, 11:28 PM | #2 |
RCC Addict Join Date: Aug 2005 Location: Naoma, WV
I've heard of filling tubing with sand and capping the ends to lessen kinking but never ice. So it turns to slushy, from the crushing force, and still stops the kinks?
08-23-2008, 11:30 PM | #3 |
I wanna be Dave Join Date: May 2006 Location: akron
that makes sense. I would imagine you have to do it pre slush stage to get the maximum effectiveness from the ice..
08-24-2008, 02:08 AM | #4 | |
Quarry Creeper Join Date: Jan 2008 Location: fair oaks nor-cal
08-24-2008, 11:51 AM | #5 |
Quarry Creeper Join Date: Jul 2007 Location: south jersey
i think the sand method would be more consistant ,i think the ice would melt to quickly since its only as thick as a soda straw,plus if want to heat the pipe for bends the sand will help retain the heat
08-24-2008, 11:54 AM | #6 |
| they did it right after they pulled it out of the freezer so the ice was good and solid, ice can be EXTREMELY strong! im curious, i want to try this now...
08-24-2008, 12:55 PM | #7 |
Pebble Pounder Join Date: Jun 2008 Location: Central Florida
Is there a problem with the stainless tubing compressing?? I thought the ice and sand trick was for very thin wall tubing. Most exhaust manufacturers use pressurized water benders.
08-24-2008, 01:32 PM | #8 |
RCC Addict Join Date: Jun 2008 Location: Fresno
08-24-2008, 02:43 PM | #9 |
| brakeline will start to deform in tight bends for stingers and stuff like that, thats why they used sand inside the brake line, but im wondering if this ice trick will work as good or better.
08-24-2008, 02:49 PM | #10 |
So the ice is on the outside then? Or did I read that incorrectly? The slushy effect I was thinking of was the ice being crushed inside the tube, but I'm no ice expert so maybe I need to watch the show.
08-24-2008, 04:57 PM | #11 |
ice on the inside, they filled the pipes with water and froze it, so when they bent it the ice on the inside kept the wallas from collapsing
08-25-2008, 04:22 PM | #12 |
Pebble Pounder Join Date: Oct 2007 Location: O-town
sounds like it would be a big mess and if your were sitting down you might wet your pants........ |
08-25-2008, 10:03 PM | #13 |
Rock Crawler Join Date: Aug 2007 Location: Atlanta
i would think that if the metal got that cold it might crack |
08-26-2008, 07:07 AM | #14 |
Quarry Creeper Join Date: Feb 2008 Location: Weddington
I think this should turn into a Myth buster episode |
08-26-2008, 10:55 AM | #15 |
RCC Addict Join Date: Apr 2007 Location: RAMBLIN
it was water and soap mixed together and deepfrozen . the soap acts as a lube inside the pipe.
