Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tools, and Procedures
Thread: can a dremel cut...
Old 08-15-2005, 09:29 AM   #1
Default can a dremel cut...
... a 1/16 sheet of stainless steel? i only need to cut holes like 2"x1".
ILoveRCRockCrawlin is offline   Reply With Quote
Old 08-15-2005, 11:31 AM   #2
savages Rule
Guest
Posts: n/a
bob said he would do it for u
Old 08-15-2005, 11:40 AM   #3
I don't see why not. I cut 1/4 steel and aluminum solid rod with mine, using a fiberglass reinforced cutoff wheel.
AdamF is offline   Reply With Quote
