01-14-2009, 09:31 PM | #1 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
| dremel diamond cut off wheel...........
anyone ever use one in this hobbie....i just bought one today from lowes for 20.00 bucks with the quick detatch feature....the regular cut off wheels took forever to cut 1/8" alum stock.............bob .... |
01-14-2009, 09:39 PM | #2 |
Pebble Pounder Join Date: May 2008 Location: Milwaukee
What types of material have you used it on other than stated?
01-15-2009, 09:05 AM | #3 |
i used the regular one on 1/8" steel plate and 1/8" alum and it took forever it seems....i saw the diamond wheel and thought hey, why not it should last longer and cut better....the regular wheels are 10.00 bucks for 5 and they don't really last long enough....my thought is if the diamond wheel lasts longer then 10 regular wheels it pays for itself....i'm going to try to get some stuff cut today with it to see if it's worth the 20.00 bucks....the diamond wheel is less then half the thickness of the regular wheels and looks to be a steel wheel with the diamond dust on it....i'll get some pictures of it with my digi calipers..............bob .... |
01-15-2009, 10:30 AM | #4 | |
What kind of digi caliper you have that takes pictures? | |
01-15-2009, 10:49 AM | #5 |
Pebble Pounder Join Date: Sep 2008 Location: Temecula
The Diamond is for ceramic. I use the new style mandrel and wheel, it says it last 2X longer... I built a hole chassis and I still have about 1/2 left. I was cutting 1/8" rod and some 3/8" tubing. |
01-15-2009, 11:13 AM | #6 |
Rock Crawler Join Date: Jul 2005 Location: Central Coast
You can also get the reinforced cutting wheels at sears. They work pretty well |
01-15-2009, 01:16 PM | #7 |
Rock Crawler Join Date: Sep 2008 Location: N.E. Mpls
ok here we go. Most abrasive types of cutter heck most cutter in general and stones also will load up with alum. When that happens it creats heat more heat more loading ect. Pay attn to the cutter if you see lil bits of alum on the cutter stop and clean it up. With the reg cut offs that loading will cause uneven wear and that when the wheel will start getting out of round. Then it will crack or just blow apart. If cutting alum. use a slower rpm and watch the cutter...If its loading it isnt cutting... Same as a grinder,,,if the wheel and grinder isnt set up for alum they can and will explode. The excess heat will cause the wheel to get hot and crack. Same effect on the small dremel cutters. I havent tried a diamond wheel yet and should try one out. Just a nore for you all useing the reg cut off wheels... Good luck and be safe. Oh ya safety glasses. And clamping or hold the part to be cut in a firm safge position will also help the wheels last longer and be alot safer... Last edited by Lonewolf; 01-15-2009 at 01:17 PM. Reason: spelling |
01-15-2009, 06:18 PM | #8 |
| camera not calipers i proof read my posts before clicking submit, but i guess i missed one .... here's the diamond wheel and tung cutting bit i bought for bird mouthing the 3/16" tube for brazing....the thickness of the wheel in mm.... i got tired of going through 3/16" chain saw stones so i bought this.... the wheel cut the 1/8" alum real nice and didn't load or get hot to the touch at all....the tung bit did a nice job on the bird mouth of the brake line ................bob .... |
01-15-2009, 09:09 PM | #9 |
Whats that??? I know what its used for (I think) Who makes it and where to get ... It looks like it would grab alot and rip itself apart ??? I dont wanna call it a "stone" abrasive something lol |
01-15-2009, 10:00 PM | #10 |
dremel makes it..............bob .... |
