01-19-2009, 09:01 PM | #21 |
RCC Addict Join Date: Jan 2007 Location: San Jose
Okay Offroader. I used caliper and the 3mm cap measured 5.34mm. So, I think the guy gave me the wrong part number, but now thanks to you I know exactly what I am looking for in terms of hole size. Thanks. |
01-19-2009, 09:25 PM | #22 | ||
I am more focusing on delrin now. I see and thanks for letting me know with alum this process is a little more delicate i guess. Thanks for the part number and helping me find this hard tool....lol. Can you explain what a step drill is and the use. Thanks. Quote:
So about 1200 rpms for alum than and should this work for delrin, what i said above. THANKS A LOT FOR THE ADVICE. Trying to learn and do this stuff on my own. Last edited by 5150bronco; 01-19-2009 at 09:29 PM. | ||
01-20-2009, 12:42 AM | #23 |
Rock Crawler Join Date: Apr 2008 Location: On the Snap on truck
Any material can bite you back, safer to clamp whatever it is down Unibits are teh best, dont buy knock offs ,they dont spin true or cut as well as a "Unibit", get the ti ones or for steel get the cobalt ones, and they even make metric ones, but harder to find 1200 rpms and not clamped down is asking for a big hurting, more like 500 rpms, you dont want speed for delrin without coolant. Oh and my set is from m3 to m12 ,m3 and so on will do any type of socket cap , so if you are using a m3 bolt you use a m3 counterbore. Last edited by Joat; 01-20-2009 at 12:59 AM. |
01-20-2009, 09:15 PM | #24 | |
what do you mean by coolant for delrin? So, you mean clamp down the material you are going to drill, right? Thanks for the help! | |
01-21-2009, 12:19 AM | #25 | |
http://cgi.ebay.com/Irwin-Unibit-Ste...QQcmdZViewItem If your gonna try to cut delrin at 1200 rpms you may want to use a cutting coolant http://littlemachineshop.com/product...=2236&category= this is just an example, not sure if this could be used on delrin, I dont see why not but have not tried ? You would need a flood or mister http://littlemachineshop.com/product...=2725&category http://littlemachineshop.com/product...=3521&category= | |
01-21-2009, 08:13 AM | #26 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
Why not countersink? The purpose of countersinking is to make the head flush while removing less material and allowing the screw head to actually strengthen the piece with the removed material. |
01-21-2009, 11:04 AM | #27 |
I wanna be Dave Join Date: Dec 2007 Location: Not here
Countersink aka c'sink will not give you a flat bottom, counterbore aka c'bore will give you a flat bottom. Depending on what type of screws you are using would dictate what tool to use. A step drill is a drill that has lets say a .250 dia pilot and .375 dia drill, The .250 pilot drills through the material and the .375 creates a .375 c'bore x what every depth you want. Kinda hard to describe, I will post up a pic of a step drill later. C'sinks come in different angles 82 deg's 90 deg's 120 deg's included angle meaning both sides add up. So a 90 deg tool will cut 45 on each side 45 + 45 = 90 included angle. |
01-21-2009, 11:58 AM | #28 |
I understand Mayhem...my point was to the original poster. I'm a huge fan of C'sink over counterbores. Trying to figure out why he's stuck with CounterBoring...unless like you he has a mill. Mayhem, something I've always wanted to ask you...why don't you use c'sink screws? They'd be flatter on the face. Only problem might be your ring design that helps with the bead. I know I've not tried countersinking my Mayhems, but every other Beadlock I've bought is countersunk with strong black oxide screws. |
01-21-2009, 12:11 PM | #29 | |
I understand. As far as c'boring my rings it was just the way we headed. We ordered screws with the flat backside and that lead to the c'bore. We buy screws 15000 at a time and get a good price on them I would hate to change and the price of screws goes up......I will take a better look and see if there is any benefit to switching. The black oxide screws cost more and we will provide them if the customer wants them they just need to ask. Quote:
01-21-2009, 02:27 PM | #30 |
Ok makes good sense, I was just checking to see if you've noticed a problem in c'sinks or their screws. I know it does get iffy with the angles...I bought the wrong c'sink bit once...LOL
01-21-2009, 07:57 PM | #31 | ||
It is just really hard to find this tool. Only place I found is rutlandtool with part #11673500. Please post pic. As of now I just bought a drill press to do this. Any suggestions welcomed. Quote:
01-21-2009, 09:44 PM | #32 |
| Step Drill
Step Drill c'bore I use this tool for my vise jaws. |
01-22-2009, 12:40 AM | #33 |
01-22-2009, 08:47 PM | #34 | |
| Quote: Thank you mayhem! Where can I get one of those????? I think that tool "step drill" may be better for plastic than "C'bore" Thanks joat for the ebay url! Cant wait to get this going....... FYI.......the counterbore tool part #11673500 I listed below is only good for metal....NOT PLASTIC OR DELRIN according to rutlandtool expert........ | |
01-23-2009, 02:10 AM | #35 | |
01-23-2009, 08:47 AM | #36 | |
One is overconstraining when using countersinks. This is especially true as more and more parts are bolted together in an assembly. A counterbore has more side to side movement. As you tighten a countersink, the angles meeting together is what locates the part.....even with clearance on the shaft, the head determines the location. As tolerance stackups add up, this can be a problem. Another is the hoop stress that is generated when using countersinks. Torquing can split the material that the countersink is exerting force into......you've probably seen this if you've ever overtightened a countersink into a plastic part. Counterbore load is axial.....force is only applied straight down on the flat surface. Don't get me wrong......I like both and they each have their place. It's just that aesthetics shouldn't be the only consideration. | |
01-23-2009, 12:38 PM | #37 |
Thanks CHUD. That is right. I want to concentrate the force applied and I want a flat surface to for the bolt. Still trying to find the tool, but will post pics soon, when I figure out how to resize the pics. This is mainly for the skid plate and mounting the tranny up. This is what I am trying to do now and I want to do it right. |
01-23-2009, 03:11 PM | #38 |
So, I just ordered and found a step drill for 3mm cap screw at Michigan drill part #371M for 13.95 shipped. We will see. |
01-23-2009, 07:05 PM | #39 |
01-24-2009, 02:25 AM | #40 |
